Originally Posted by stormwind13
Thanks for taking the time to make this spreadsheet. I was considering popping $1500 on a pair of QSC Kw153 before I saw them ranked just slightly below the Klipsch KLF-30 that I already have. Maybe could just plunk down 75 bucks on a bob crites diaphragm upgrade and call it a day.
I'm glad you've found some use in the spreadsheet. But...
What are you trying to achieve in thinking about buying the QSC's? There's the amplification advantage that I mention below, a different horn that will sound different from the Klipsch, different directivity as far as how even the frequency response is at different angles off-axis (which may affect listeners on the sides, or how the sound reflects off of untreated walls, etc.). In other words, depending on your goals, there may be a number of factors to regard other than raw SPL.
And even that is difficult to judge... did I translate the max SPL of the QSC correctly (it's extrapolative when they don't give you sensitivity)? Check out their spec sheet and see what you think about their max SPL spec. It may work well for your needs. And where does power compression set in with each speaker? (see above posts) For all I know, one speaker exhibits compression at 1/5 power, and the other at 1/10th power. But we'd need 3rd party measurement, or at least anecdotal reports, to know that.
Active Amplification
To be fair, I read that active speakers that have separate amps for each of the drivers are more efficient with the power allocation than one amp driving all the drivers with an analog crossover.
I think I may have accounted for that when I can see what the low frequency amplifier puts out. But I may be under-rating a speaker where they only gave one spec for total amplification.
wrong topic
, wrong thread. Never mind & carry on.
