Originally Posted by
s.myers
That being said for those without a treated room and looking for an above avg HT setup would sensitivity and reference be as important? When I say above avg I'm assuming approx five thousand for entire setup tv, receiver and speakers.
I think you're saying,
'If their room isn't treated, so they don't lose as much volume; they keep more sound from reflections. So therefore, they shouldn't worry as much about sensitivity?'
While it's true that without treatment you can get the dB louder, I hear it's also more difficult to listen to as you get louder [without treatment]. The acoustic energy of the reflections swamps the direct sound more.
So, if they don't want to treat the room, it'll sound not-ideal when the volume isn't up, but it'll sound even worse when turned up.
In other words, they can't go very loud, and the ~$3k for audio equipment was wasted, to an extent.
s.myers
Fir example how would say the Ascend sierra's rate with their lower sensitivity? People seem to like them very much. I would be more interested in great detail like hearing a pin drop rather then shatter my windows or have the nails pop out of the house framing lol.
I've noticed in commercial theaters that were not that nice, definitely did not play at reference levels, that still the dynamics were much higher than at my house. The dishes clattering on the table. The sudden roar of the engine when it accelerates, the gun-shot, the yell to "Look out!" Everything seemed more alive, more exciting.
In actuality, all those dynamic peaks were probably lower than they would be in reality. The engine roar, the jet, the gunshot. The latter especially are 30db on up more than reference level peaks.
That's why the dynamics are more engaging...the sound, while still not perfect reality-fidelity, are more like life. Your adrenalin will response more. You grin and think, "This is how it's supposed to be." Just like moving from VHS to DVD to BluRay. Or getting that display that can portray inky blackness, instead of grays, of deep shadows, or outer space.
If you ONLY want to hear the micro dynamics of softer sounds, you should get equipment and a room with a very low noise floor, so you can turn down the volume and still have the dynamics peaks within capabilities.
But even then, room reflections will blur the accuracy of the sound. If you want the pin-drop accuracy, you need to treat the room to mitigate the reflections until after 20ms. If you can't, at least horn-loaded compression drivers can keep more of the sound pointed at your, and less at your walls.
pokekevin
I actually would like to try those exact same speakers too! Somebody on this forum recently did a comparison between Sierras,veritas ,and RCs and I believe he prefered the Sierras.
The sensitivity speaks nothing of the SQ of a speaker. Just shows you the power needed to play (higher sensitivity needs less power to go loudddd). I believe Ascend recommends 45wpc at least. If you got the amp to power em than go for em!
I added the Sierra-1. There are always trade-offs in speaker design. I think a lot of the time the speakers are targeted for two channel music, where people are looking to play without a sub. For home theater, I would've much rather they sacrificed some extension I don't need, in return for more sensitivity. 85-86db is pretty low! 89dB (middlin' sensitivity) with extension to 60hz would've been fine.
This is more of a "play at -14" speaker. Which is fine if that's what one is after.
pokekevin
What about reveberance? Either way I still wouldn't listen at ref lol
Well, the funny thing is, when people complain about "loud" (especially women, I hear), they're really complaining (without realizing it), "This system sounds terrible loud in this room." If Dennis Erskine had designed the room, it'd sound better, loud or not. And if the equipment was properly spec'd, it'd sound even better. The dynamics would be present, and you wouldn't be hearing the distortion.
Imagine you're driving in a car more suited for in-city driving. On a poorly-banked road that has some loose gravel over the asphalt. You try pushing it to 95 mph. You try to accelerate and it takes forever. It feels out of control, and when you hit some curves the car feels like it's about ready to fly off the road. It tilts dangerously. You pull off at an exit to end this nightmare, and exclaim, "I'll never drive even close to 95 mph again! It's so dangerous!"
Now try a try a sports car that has great handling, acceleration, and top speed. The same road is just as rough, but the car handles the acceleration, the curves, and 120 mph with aplomb. Completely different experience!
The first car may have had a great sound system, climate controls, insulated cabin, turning radius, and fine leathers from purpose-bred animals on a remote mountaintop. It does fine driving at less than 70 mph, and not accelerating quickly, which is 90% of your driving.
But for fun, adrenalin, excitement, isn't the second car more satisfying, for those other 10% occasions?
And how much better would it be with a great road (room)?
Remember, the point isn't "Can I reach reference level" or "Should I reach reference level." It's that most of us are probably listening to movies with lots of distortion, without dynamics that the sound designers intended.
