AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Archaea's Kansas City Blind Subwoofer Shootout 2012
Archaea's Kansas City Blind Subwoofer Shootout 2012 - Page 29
post #841 of 848
Originally Posted by Jon Lane View Post
-which, I certainly did, obstruction being the intent around here. Bravo. Of course, I caught and deleted that remark when, after sifting this unmitigated barrage of unanswerable nonsense, it dawned on me that that's precisely its point.
It'll teach me not to engage on this level.
Wow. Now it's our fault that you post first, think later. Classic.
Literally. This is classic Chase morphing into "Chane".
Say what you want without regard for a basis in reality. Change your mind. Delete. Never happened. But if it did, it wasn't my fault.
Right?
Gear mentioned in this thread:
post #842 of 848
Right?
You got your mea culpa - as I said, I've learned not to (re)engage at this level, an instinct I formed weeks ago just before the first failed Chase narrative bombed. Now it's two down.
What I would do if I were you, though, is relabel all opposition all over again, preferably before the fact.
Classic morphing, I believe the term was, and something about a basis in reality.
post #843 of 848
A mea culpa would require admission of having made a mistake by one's own fault; not admission of having made a mistake by someone else's fault. tongue.gif
Regardless, let's continue- as it seems you've already decided to change your mind about "engaging on this level". rolleyes.gif
"No worries, he's sufficiently incoherent to have me making the same mistake, a blunder he's now taking me by the ear to the veritable woodshed over. I'm considering taking up needlepoint, little that I know.
Seriously, this kook is carping about a ten percent difference in Fs? Probably between two different samples or two different conditions, whichever? And without a concurrent analysis of how, given this monumental 10% margin of error/sample variation/conditional variable, given the same driver all other major parameters will adjust with it, bringing the system response back to probably within a few percent, or maybe a dB? In a system like any other anywhere in its class run with many dB of equalization and at-power thermal variations - like any driver - probably 10x that vast chasm of, what was it, the unholy deception of ten whole percent?
This guy knows less about the subject than he should ever admit in public."
Let's take that last line and let it sink in for a moment.
Quick again to post some simple math before even taking the time to understand the basic context.
The only "kook" carping about a ten percent difference in Fs would be Craig who, without sharing this 19.4Hz Fs measurement from Paul Apollonio at the time, used the same to throw all of my measurements out the window as "invalid". Because I had measured an Fs of 21.53Hz, nothing I had measured could be correct because Paul measured an Fs of 19.4Hz.... and there is just no way in the world this is reconcilable in our universe.
Ridiculous of course, but I don't have to explain why. You've done that well enough in this quoted post.
You see, Fs was never the issue. I measured a close-mic response, simulated the same response using T/S parameters I measured from a driver and compared them to the 23-200Hz +/-3dB specified response of the subwoofer as I had purchased it.
They were vastly different.
Craig denied all because he noticed a difference in Fs between my measurement and Paul's and was able to use that as his "out".
Now the truth comes out; the original spec from Eminence, my measurement, Paul's measurements. As you note, "two different samples or two different conditions..."; nothing here to justify throwing data out the window.
You know this. You've unknowingly argued my point here convincingly.
As for our mutual friend, I think you summed it up best:
"This guy knows less about the subject than he should ever admit in public."
post #844 of 848
Quietly acknowledging the past and moving on is a gift to all concerned forum members. No opinions are being changed on either side at this point and there is no merit in further feuding. Find something positive from all this discussion and consider it a personal keepsake!smile.gif
post #845 of 848
Well, which is it? You seem conflicted.
Entering this debate is admirable because of the spewing of miss information and the misuse of data to support erroneous conclusions over at AVS is unacceptable on a science forum. Taking a stance against something that is wrong in information and the spirit of the debate is not something to be passive about, it is just a matter of planting one's feet firmly in what is right."
In any case, I heartily concur with "taking a stance against something that is wrong in information". tongue.gif
Also, to further respond to Lane's cheap shot about knowing "less about the subject than he should ever admit in public", I will gladly defer to many that have already posted in this thread and their knowledge of this subject and/or subwoofers in general. You won't get any argument from me.
I see Jon's chosen to flex his touted knowledge superiority in responding to my points in a very... interesting manner:
"Craig, if I re-moniker my account something vaguely alluding to vast expertise in bass, then can I post anonymous rubbish about bass response in general?
Like BassMaster. Or TenHurtz. Maybe DeciBelzQbed.
Because I think I'm seeing a trend over there."
post #846 of 848
Looks like Jon & Craig can't stay on the same page.
Craig decided he looks pretty foolish with Jon calling him out unintentionally and is going all out in defense of these Fs measurements (that were never in question by anyone but himself):
Our drivers are measured pre burn in by Eminence. The follow up question is: Two measurements were taken on our Eminence driver. One is from an individual who seems to be obsessed with trashing our products. This is "A". The other measurement is from an industry professional with 30 years worth of experience in designing loudspeakers. This is "B". "B" has zero to gain or lose when measuring our products. He is getting a fee, and providing information as requested for his fee. This professional measures, with some of the best equipment available, a drop in Fs of 9.35% after the driver is broken in. The other party measures an increase of 0.6 %.
As a hobbyist, you are wanting to use the most accurate measurement for Fs before building your project. Will you take:
1. Measurement "A"
2. Measurement "B"
Jon unknowingly countering Craig's position that this difference is 'significant':
Whoever this kook is he's also claimed it's deceptive to call a 21.40Hz Fs a 21.53Hz Fs.
-A difference of less than 0.1%, or well inside the measured specification of probably any pair of drivers ever made.
Maybe Jon will come around and figure out who this 'kook' is he keeps referring to. Or perhaps "this guy", and what he should admit in public. We can only hope. tongue.gif
post #847 of 848
I find it utterly comical how much time some people will devote to cht bashing. How many countless hours have you lost now crafting up witty responses and analyzing every sentence that others post? I guess if it floats your boat, great.
post #848 of 848
Correct. That's all there is to it. Here it is (and always has been):
And, if you connect the passive version to a pro amp, as CHT has suggested, the F3 is even higher.
"No worries, he's sufficiently incoherent..."
I don't know who this Jon guy is but he should probably lose the CHT method of debate and learn how to measure a sub, correctly read the results and state the response. After that, he can teach his new boss.
The sub never approached a 23-200 Hz (+/-) 3dB response, as the specs were published. The rest of this silly argument, that CHT has dragged out over years, is drivel.
