AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › Playstation 3 250gb or 320gb ???
post #1 of 6
Hello, im a first time user so please forgive me if i havnt done this correctly but i was wondering if anybody knows or can advise me about playstation slim. I currently have a ps3 80gb fatty (albeit broken earlier this week) and considering buying a new one tomorrow. I understand the slim is now far superior and lighter, uses less power etc but i dont really know if there are any fundamental differences between the 250 & 320 other than memory size. Does one perform better than the other ? Does one have a reliability record higher than the other and does any of them play ps2 games like the old 40gb. Your comments are much appreciated regardless of how minor you think they are. Thankyou in advance
post #2 of 6
The 250GB version is discontinued, as far as I can tell. The current 320GB version has newe hardware inside it, but it does the exact same thing and isn't more efficient enough to care about. If you walk in to a store to buy a new one you'll get the 320GB for $300. If you can find a new-in-box 250GB for less than $250 then that would be a perfectly reasonable purchase.
post #3 of 6
Niceone fella. Thankyou.
post #4 of 6
Is there a difference between the 160gb & 320gb ?
post #5 of 6
Yes, the size of the hard disk inside the PS3 is different.
post #6 of 6
The OP already said other than the hardrive size thats why i didn't put it in my post
  Back to Forum: PlayStation Area
