Hey guys-
I live in a home with Cat5 wiring throughout (4 rooms have Cat5 jacks). The Cat5 cable from each port on the wall goes into a central Leviton system Box in the laundry room. Each Cat5 cable in the box goes into a PCB w/ white connectors for each individual wire (see attached pic). The PCB appears to be a HUB, but doesn't have RJ45 Jacks/ports- just individual wires from each Cat5 cable that slides into the connector.
The problem is when I hook up my Router to the RJ45 port in one of the rooms- and a laptop in another room- I don't get a connection. I'm positive it's not the problem of the laptop as I've tried multiple computers and connecting cables.
Each cable in the Leviton box has a orange+orange/white, Blue+Blue/white, green+green/white, and brown+brown/white.
I have a cable modem connecting to the router. From the router ONE of the ports plugs into the wall port. I then plug a laptop into a wall port somewhere else in the house and get nothing. I know the Modem/Router are working as I get internet when I connect directly to the router (which is what I'm using to post this here). It's a cable modem and gigabit router.
What am I missing?
Thanks guys!
What am I missing?
Thanks guys!
