AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Pivos AIOS HD Media Center: The *Semiofficial* Thread
Pivos AIOS HD Media Center: The *Semiofficial* Thread - Page 36
post #1051 of 1110
Originally Posted by JimLely View Post
Has anyone used a capture device such as the Hauppage PVR2 to capture video to your PC's HDD and ultimately play the video files on the Aios.?
Do you mean live streaming ? well, its doable depending on how the streams are formated
post #1052 of 1110
No, I want to copy the HD movies from my DTV HD DVR ( before the DVR croaks) via a capture device to my PC's external HDD. Then hook up the HDD to the Aios. Here are the relevant specs for the Hauppage:
H.264 AVCHD high definition video encoder, video encode to 1080p30 from HDMI or component video
No delay HDMI pass through: HDMI or Component in to HDMI out, up to 1080p
Recording datarate: from 1 to 13.5 Mbits/sec
Recording formats: MP4 or TS
post #1053 of 1110
That should work without an issue,
Do you have a problem running these captures ? paas a sample through media info and post the output here.
post #1054 of 1110
Haven't bought anything yet but I'll post after I do.
P.S. Got my second replacement Aios from Pivos last week. These Pivos people are an A-1 classy group -- great people. (Yes, and I already reviewed the Aios on Amazon earlier this year.)
post #1055 of 1110
any word on USB flashable of newest firmware yet? i know you said you were moving weeks ago so no biggie im just waiting... smile.gif
post #1056 of 1110
I, too am in need of an extra hot-swap tray.. or at least a pair of the latches. (Seems the "ears" that keep it latched have broken off.
post #1057 of 1110
As you requested:
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 1h 54mn
Bit rate : 13.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.221
Stream size : 11.1 GiB (92%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 1h 54mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 37ms
Stream size : 316 MiB (3%)
post #1058 of 1110
Aasoror, i got updated to 22.3 thanks
post #1059 of 1110
Is better that wdtv live ?
post #1060 of 1110
to me yes plays pretty much anything i like it
post #1061 of 1110
Better, I wouldn't say better but the AIOS does play DTS-MA and True-HD. WDTV doesn't play DTS-MA unless you buy the latest WDTV live, which plays DTS-MA, but doesn't decode True-HD or something like that.
The AIOS stock remote is unresponsive, a Harmony remote or something similar is recommended. For what you pay for it, the AIOS isn't bad, but remember is a very simple media player don't expect to have the same features as Dune, Mede8er and PCH media players.
post #1062 of 1110
in which aspects is better?
play isos, mkv. iso bd, etc.
has audio output dolby surround
post #1063 of 1110
Glazing,
You need to start doing a little more work on your part and stop asking question that can be answered buy just using Google or at least go to the manufacturer's website and look up for the specs yourself.
post #1064 of 1110
Contact support, they should be able to take care of you (you will need to just pay for S&H).
As you requested:
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 1h 54mn
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 54mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Nothing much except for CABAC with 1080p, if there is an option to disable CABAC I would go with that
post #1065 of 1110
no problem, i want to install that jukebox but im totaly lost on how to do it confused.gif
post #1066 of 1110
I'm using the DLNA feature on my Yamaha RX-A1000 for my music and wondering if Pivos AIOS HD Media Center would be better than this option? If yes why? Due to my living space my PC is at the opposite end of my living room so it is not possible to run any cable from the PC to my Yamaha. I "stream" the music/movies(both blu-rays/dvd's) from my PC through my Asus (darkknight) router using Cat6(35ft) run to my Cisco switch and out to my PS3,Panasonic 230 Blu-ray player(using Cat6 to all devices. So would the Pivos AIOS HD Media Center offer any improvement given my setup over say PS3 Media server,Plex,Jriver in sound quality or flexibility? How close is the Pivos AIOS to a HTPC(which I can't use due to the way my apt. is wired only 15 amp fuses) Thanks for any help!!!
post #1067 of 1110
I would not consider getting the WDTV Live unless it supported HD audio (DTS-HD MA and TrueHD).
post #1068 of 1110
I have both players, a Live and the Aios and overall the Aios is better even with all the extras that the WD users added to the Live as far as widgets and goodies. If all you want to do is play just about anything smoothly and be able to chapter search the Aios is better by a long shot and is better at Blu Ray ISO playback as well but still has some issues.
The Live has better file layout as it has many file sorting options the Aios just doesn't support, like being able to sort by date added, alphabetically, etc , It also will keep the USB ports live when in standby so your extra drives still show up if shared on the network when the live is sleeping, the Aios is only active when turned on.
All this only applies to a live that has the modded firmwares installed, just like we do with the Aios. I have both hooked to my network but I almost 100 percent use the Aios now and the live just shares my two big external drives so I can edit, swap files around, and like that on the PC here without having to turn either unit on, also the Live will transfer files faster too, even though it's only a 100 based speed, but both are slow compared to just hooking the drives to a USB port on the PC here.
post #1069 of 1110
Aasoror,
I have an unusual situation with my beloved AIOS. I've had the unit for about 1.5 years, and everything ran great with every one of your SO (semi-official) firmwares. This weekend, when I decided to update to SO R22, my power supply died sometime after I started the panic recovery updating process. I don't know how far the process got, because I walked away from the AIOS and when I came back few minutes later, the unit's blue light was flashing (about once a second) and there was a faint clicking sound coming from the unit with each flash. I unplugged the power supply and used another one to start up the unit. The AIOS started up and everything seemed fine, but when I went into the File Manager, I did not see the HDD icon; I only saw the Network, UPnP, and NFS icons. (I have a 2TB hard drive in the AIOS, filled with movies, and the drive has worked great in the AIOS since I bought the player.) When I back out of the File Manager, I can scan the HDD for files from the main menu by pressing the green button, and I can view the movies under the Video browser menu (the option just below the File Manager on the main menu). I tried reflashing (via panic recovery mode) the SO R22, the SO R10 (with BC18), and the latest official firmware, but none of those firmwares displayed the HDD icon. On the main menu, the hard drive indicator icon is white instead of grey, which means the AIOS does see the HDD. I even reformatted the drive in the AIOS, both with the standard format process and the EXT3 but to no avail. I then formatted the HDD when the AIOS was plugged to my computer into NTFS; no go. I used two other 1TB hard drives with the same result. Everything seems fine except that missing HDD icon in the File Manager. I can access my movie files with the Video browser menu, but that view does not categorize my organized folders.
Oh, one more thing. When I view my movies via the Video browser menu and I then press the OPTIONS button on the remote, I can access the File Mananger by selecting the GO TO FOLDER option. I then can navigate through my folders as via the File Manager, but as soon as I back out out of my last folder, it kicks me back to the File Manager's first menu, and I only see the Network, UPnP, and the NFS icons. And just before that menu, as I'm backing out, I see a blank menu screen where the HDD's root directory would be.
(Maybe I should create a folder.jpg file for my HDD, place it at it's root directory, and see what happens.)
Anyways, have you heard of such a thing? And if this issue is caused by a corrupted BC18, is the BC18 reloaded with R10 every time I flash it, or do I have to flash the AIOS with an older, pre SO R10 or official version and then reload the R10 with the BC18? Thank you.
Edited by MarioV73 - 9/30/13 at 9:08am
post #1070 of 1110
mmm .. thats pretty strange, something got corrupted for sure, but I don't think its the HDD itself.
What about USB storage ? can you see that fine ?
can you telnet to the AIOS and execute
Code:
cat /proc/partitions
Then
Code:
mount
And see what kind of output you have ?
Originally Posted by MarioV73 View Post
Aasoror,
post #1071 of 1110
Thank you, aasoror, for the quick reply. Yeah, I too think the firmware/bootcode got corrupted when the power supply died, and not the HDD. What I don't know is how the firmwares and bootcodes are updated with each panic recovery updating process, whether some of the code remains unchanged even though the majority of the code is being updated. For example, is the bootcode being updated every time I flash a new firmware, or is it only flashed with SO R10, or is it only flashed when a different version of the bootcode is detected to be flashed? Is there a way to go back to the original bootcode, prior to BC18, and then try reflashing to BC18? Will any of the early official firmwares reflash the bootcode to the one prior to BC18?
Anyways, I'm currently at work, but as soon as I get some time tonight I'll post the telnet results you requested. Thanks again.
post #1072 of 1110
Only firmwares indicated to have a new bootcode will update the bootcode (currently semiofficial R10+BC18).
The rest of the firmwares will just replace the "root" (operating system) and "usr/local/etc" (user data), when applied in panic recovery, or just "root" when applied from the AIOS interface.
So in theory everything gets cleaned up with panic recovery update.
post #1073 of 1110
I see, so with every reflashing of the SO R10 and its BC18 the bootcode gets updated, and therefore a fresh copy of the BC18 should overwrite any corrupted one. Hmmm... I'm hoping this is not some hardware issue caused by the flickering power supply. Is there a way to wipe the BC18 in my AIOS with a different BC, and then overwrite that other BC with BC18?
Also, you asked earlier about the external USB drives, ... I did not try an external HDD in my USB port since this issue occurred, but the thumb drive I used for the panic recoveries was recognized in the AIOS's File Manager after it booted up, because I left the thumb drive in the player while I looked for the internal HDD and the USB icon popped up next to the Network, UPnP, and UFS icons.
Tonight, I'll reflash several versions of the firmwares, include the SO, official, and XtrAIOS, and reformat the drive and the few other drives I have laying around and see what happens. But it would be helpful to get a hold of a firmware with a bootcode that is different from BC18. Would any of the firmwares by other manufacturers work? I know of at least one other player that uses the Realtek 1185 chip set. But although that player is a distant twin of the AIOS, that player lacks some of the hardware features of the more superior AIOS.
post #1074 of 1110
Bootcode from a different player will brick your AIOS (even if it is the 1185 based box).
Realtek hasn't made any bootcode in flashable format available to the AIOS but BC18.
I don't think its bootcode related either, something in the file system is messed up (even though its cleared by panic recovery).
If you have a chance execute the two commands above and let me know the output.
post #1075 of 1110
aasoror,
Last night I messed with my AIOS, and after I redownloaded the SO R10 and reflashed it, everything seems alright. When I was flashing the SO R10 earlier, I was using a copy I had sitting around since over a year ago, so it might have gotten corrupted. Right now I have R22 running and everything is beautiful. It's great having someone like you helping the AIOS community. I'll just have to grab another AIOS, since they are back in stock.
Thanks again.
post #1076 of 1110
aasoror,
Thanks again.
Enjoy your AIOS ..
post #1077 of 1110
aasoror,
I was curious, and I telnet to the AIOS. This is what came out:
~ # cat /proc/partitions
major minor  #blocks  name
  31     0      25472 mtdblock0
  31     1      95360 mtdblock1
  31     2     128000 mtdblock2
  31     3      13312 mtdblock3
  31     4     262144 disc
   8    32 1953514584 sdc
   8    33 1953367447 sdc1
   8    34     136552 sdc2
~ # mount
/dev/root on / type squashfs (ro)
none on /dev type devfs (rw)
none on /proc type proc (rw,nodiratime)
devpts on /dev/pts type devpts (rw)
none on /sys type sysfs (rw)
none on /tmp type ramfs (rw)
/dev/mtdblock/2 on /usr/local/etc type yaffs (rw,noatime)
/dev/rd/0 on /mnt/rd type vfat (rw,nodiratime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1)
/dev/scsi/host0/bus0/target0/lun0/part1 on /tmp/usbmounts/sdc1 type ufsd (rw,nodiratime,nls=utf8,nls=utf8,uid=0,gid=0,fmask=0,dmask                                 =0,force)
I have one 2TB hard drive in it and one Pivos Wifi adapter in a rear USB port. For some reason the LAN port green light is always on, even when the cat5 wire is not plugged in, and I can't make a wired connection to my router. Any ideas?
post #1078 of 1110
aasoror,
  31     4     262144 disc
   8    32 1953514584 sdc
   8    34     136552 sdc2
ok there is nothing wrong with that (now that you have cleared everything with reflash), you 2TB is mounted under sdc
mmm that shouldn't happen, LAN LEDs should turn off as soon as you unplug the network cable.
Did it always do that ? where you ever able to get it work ?
post #1079 of 1110
ok there is nothing wrong with that (now that you have cleared everything with reflash), you 2TB is mounted under sdc"
That's good. And what do sdc, sdc1, and sdc2 mean? Why do I have two 2TB mounts? Is there a telnet tutorial for Pivos AIOS on what the commands do and how one could modify the settings?
 mmm that shouldn't happen, LAN LEDs should turn off as soon as you unplug the network cable. Did it always do that ? where you ever able to get it work ?
Welp, I couldn't tell you whether it always did that. I don't recall messing with the LAN port, or paid attention to its lights until I wanted to telnet to it, but I could not. I had to use my Pivos wifi adapter to make that telnet connection. Is there a way to identify whether the LAN port is buster or is having a conflict with something, like the HD? Maybe I could use telnet to disable/enable or remount some of the AIOS's hardware?
post #1080 of 1110
I have a 1TB HD in my AIOS which is formatted with EXT3 and SWAP partition, do I have to format the swap partition, and if so how? Is everything ok below, did it format ok or what?
BusyBox v1.1.3 (2011.09.09-05:41+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
31 4 262144 disc
8 0 976761854 sda
8 1 976615447 sda1
8 2 136552 sda2
~ # mount
/dev/scsi/host1/bus0/target0/lun0/part1 on /tmp/usbmounts/sda1 type ext3 (rw)
/dev/mtdblock/2 on /usr/local/bin/nfsmount type yaffs (rw,noatime)
lionn
Edited by Lionn - 10/13/13 at 4:19pm
