Originally Posted by
Al Sherwood
Thanks for speaking up on this, given what you say I should be able to enter the login and password for the PC that contains the target files?
I tried this but still could not get in...
Have you verified the files you are trying to access are shared to the specific user for which you are using the login credentials ?
Also did you check that no firewalls will block "file and printer sharing".
You might also want to make sure that there no special characters in the user/pass.
jeff.lebowski
My issue is popping from the speakers when a 5.1 source is paused or the stop button is pressed.
It was reported with external speakers before.
It sucks, I do have that issue with the sound bar connected my HTPC whenever my bar is turned on before the HTPC, not sure if there is a way around it though.
on a second note .. the latest firmware (to be released) solved the playon.tv issue, so
playon.tv services will be accessible on the AIOS.
