Originally Posted by
aasoror
well, it depends on the encode settings, pass the file through mediainfo and post the output here.
General
Complete name MVI_0562.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 1.11 GiB
Duration : 4mn 33s
Overall bit rate : 34.9 Mbps
Encoded date : UTC 2011-08-09 18:00:33
Tagged date : UTC 2011-08-09 18:00:33
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4mn 33s
Bit rate : 33.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.671
Stream size : 1.06 GiB (96%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 4mn 33s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 50.2 MiB (4%)
Language : English
