AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Pivos AIOS HD Media Center: The *Semiofficial* Thread
Pivos AIOS HD Media Center: The *Semiofficial* Thread - Page 21
post #601 of 999
Well, I missed the deal with the rebate.
IF you should see another deal and if you don't mind, please post here.
George
post #602 of 999
Why do you say that? The rebate runs to 7/31. http://www.newegg.com/Product/Product.aspx?Item=N82E16815645001
Click the arrow next to the $74.99.
post #603 of 999
George
rebate is extended to July 31
http://pivos.myonlinerebate.com/
post #604 of 999
Ah, I meant Tigerdirect which would have dropped it to 48 bucks after rebate
post #605 of 999
I plug/unplug and move my AIOS around a lot. Yesterday the HDMI output stopped working. The cable would rock up/down, so I was worried that the socket had come loose from the circuit board.
Thought I would open it and take a look before sending in for repair. Turns out the socket solder connections were fine (they're through hole, not surface mount, so are very strong).
I noticed the socket has 2 tabs on both the top and bottom to hold the cable firmly in place. On mine, the top 2 tabs were bent up and weren't doing anything to hold the cable. I just bent them back down. The cable doesn't rock any more and the HDMI works again. Easy fix!
--Dan
post #606 of 999
--Dan
Thanks for sharing this Dan.
post #607 of 999
Originally Posted by McHoop View Post
Just downloaded something from ITrax. First download from them. WAV DTS files and before each and every track, I get a "pop" followed by a short "hiss" and then the track starts already one to two seconds in. Very annoying. None of my other audio files have done this. I also have some other WAV DTS files and no issue like this.
McHoop
I have loads of ripped DTS .wav files and had the same issue as you. This little app will fix the headers in the files so they will play. wav2dts.exe
It's from Shark's Codecs site list of tools:
DTS in WAV converter This small tool will convert unplayable DTS audio files (just static noise) which usually have a .wav extension into files that will playback using the Shark007 Codecs... instantly. Just drag n drop the unplayable file onto the downloaded executable.
You don't need the codecs obviously.
Cheers,
A440hz
post #608 of 999
Just ordered from NCIS for $69 (after $20) rebate. Home pages says $79 but when you click the product, it comes up $69.
http://us.ncix.com/products/?sku=64162&vpn=PTGMCART35-US&manufacture=Pivos%20Technology%20Group%20Inc.&promoid=1368
I have an Argosy HV335T now and can't wait to try this baby out. I currently have 834 .mkv bluray on 20TB WHS. Excuse me if I haven't read this whole thread yet but with the various FW out there, is there a decent search functionality without going Jukebox?
A440hz
post #609 of 999
A440hz
The latest semiofficial firmware has the SRJG jukebox included which is really easy to build and update (it does have search function).
The other option is to use the AIOS local media library indexing functions (which supports sorting and searching), but that requires the media to be local to AIOS (internal/external HDD) there is a workaround for that which requires linking your media folders over the network on the the AIOS local storage formatted in ext3 (its not really that hard and there is a detailed guide for that on the AIOS forums).
Best of luck,
post #610 of 999
Thanks for the prompt reply, Aasoror. I have read a number of your useful guides already and appreciate all your work. I have a 60gb ssd that I plan on popping into the AIOS when I get it. That should give me enough space to use for local ext storage to play around. I will be using network storage for all media exclusively.
I also ordered a Logitech Harmony 300 too (I've already had four other expensive Harmony remotes over the years that have stopped working right after the warranty ran out) in case I want to try out some other FW. I can't wait to get this puppy... I'm so sick of having to scroll though 800+ titles to get to what I'm looking for... this will be sweet.
I also use a couple of HTPCs but WHS, Media Browser and Shark's Codecs are too much work. I hope this little box will meet most of my needs.
Cheers,
A440hz
post #611 of 999
Does anyone here have experience with Media Center Master scrubber? It can output an .nfo file that is compatible with Popcorn Hour/YAMJ. The advantage is that it can scrub adult titles as well as IMDB, TMDB and Amazon. Would this file work for media info or do I have to use ThumbGen?
post #612 of 999
Been considering a WD TV Live streaming and just came across this, seems like I may have another option. Can someone help me on the wifi functionaily that this can offer? I have WD My Book Live attached to the network and am curious as to the possibilities to be able to stream the media to this device.
post #613 of 999
The "other" FW was already batched for official AIOS remote compatibility wink.gif
How is scrapping done is not important, what just matters is that the resulting files would match the requirements of the jukebox builder (in case of the latest jukebox it would be name.jpg, name_sheet.jpg and name.nfo)
once a compatible wifi is installed you can connect to your wifi network for local and internet streaming (just like a using a wire).
That said, wifi (as with most similar devices) is YMMV depending on your specific setup, typically you should be able to get your SD contents and low bit rate 720p rips streamed without issues over wifi.
post #614 of 999
It doesn't have built in wireless like the WDTV. You will have to buy a dongle for wireless. You will not be able to stream high bitrate content via wireless, but you will be able to stream SD and most 720p content via wireless.
post #615 of 999
You mean the Semiofficial: AIOS-SO-FW- 3.0.1.7, not The Mede8er build, right?
post #616 of 999
So to stream 1080p content like blu ray rips you would need it plugged in via ethernet. The same goes for the WD also right?
post #617 of 999
There is no Mede8er build for the AIOS, I meant the XtrAIOS.
The Semiofficial builds are based on the official ones, so its not exactly hacked, but more of "enriched" wink.gif
There is many variables involved, for example, even if you have an N adapter, your router will fall automatically to G speeds whenever a G device connect to your network (when router is operating in "mixed mode"), there is also interference with other wifi networks and other wireless devices running in the 2.4Ghz band.
I personally think a wire is the way to go, that said, there is have been several success stories regarding HD streaming on wifi, most concrete ones involved using a wire to a WIFI AP instead of using the USB wifi adapter. Using a WIFI AP you can go as fancy as you want (set up a 5.8Ghz band N network only for fastest and most reliable connection)
post #618 of 999
Gotcha, thanks. So 04/04/2012 XtrAIOS 3.0.12 is the one I want to try? Thanks for all your hard work, helpfulness, and patience. smile.gif
Edited by JHevener - 7/11/12 at 2:29pm
post #619 of 999
Yup .. thats the latest unofficial, though I would encourage you to try the latest semiofficial one (R20), the semiofficial releases are the ones I work on wink.gif
post #620 of 999
That's my plan. BTW, is Pandora on R20 or just on Xtra?
I have another question for you. Is there a problem playing older (sd) flv files via storage or just streaming them from YouTube (I see the option was removed)?
A440hz
post #621 of 999
A440hz
There is no Pandora module on R20 (not non of XtrAIOS IIRC), its shoutcast.
flv should be played locally without a problem, YT-SD module was removed because its no longer supported by google API, but there is the YT-XL module which is HTML5 based and works fine for both SD and HD YT contents.
post #622 of 999
The remote has been updated (shipping for some time already),
Glow in the dark buttons, and WAY BETTER button placement.
Pivos will start an replacement initiative soon where customers only pay for shipping and handling to replace their "non-defective" old remotes (only one free replacement per box is allowed though).
Which remote is the new one?
Jim
post #623 of 999
Jim
The one on the left.
post #624 of 999
post #625 of 999
XBMC for Droid released...
PIVOS paid for work on the point and has a an XBMC developer on staff now!!!!!!!!!!!!!!!!!!!
http://xbmc.org/theuni/2012/07/13/xbmc-for-android/
post #626 of 999
Looking good.
post #627 of 999
Guys, any new deals on the AIOS (preferrably with a chance to get the new remote).
George
post #628 of 999
It will be very useful to read this AIOS HD Media Center Review for those who are in "buying cycle"
post #629 of 999
George
If you haven't jumped yet, the MIR was bumped to $30 for all August purchases.
post #630 of 999
Thanks. Hey, how come amazon is not eligible for the rebate? Just curious as I prefer newegg anyway but then there's the thing with the remote
and you said amazon was more likely to have the new remote.
George
