AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Pivos AIOS HD Media Center: The *Semiofficial* Thread
Pivos AIOS HD Media Center: The *Semiofficial* Thread - Page 29
post #841 of 1017
Interested in this media player. Quick questions? Does it support TrueHD and DTS HD MA? Does it play dvd iso, mkv, etc.. Does it play bluray iso, mkv, m2ts, etc..?
I basically just need a media player to play my dvd and bluray rips off a external usb3 hdd or over serviio.
thanks.
post #842 of 1017
thanks.
It cannot play BD ISOs that have java menus.
post #843 of 1017
main movie iso with no menu?
post #844 of 1017
If it doesn't have any menus it should be fine, but I never tested that.
post #845 of 1017
thanks.
Answer is yes for all your questions with the following notes:
- BR ISO with Java menus only the longest track gets played (chapter marks within that track runs fine).
- ISO (DVD/BR) needs to decrypted and region unlocked while ripping (I use AnyDVDHD for that).
post #846 of 1017
If you have a BD with Java menus that has a TV series, this could be problematic. A way around this is to create a separate iso for each episode within the series.
post #847 of 1017
True, but you don't have to "create" new ISOs, if you are going to unpack the ISO just use the AIOS to navigate the unpacked contents and manually select the tracks you want.
post #848 of 1017
For a TV series, I would use TSMuxer (freeware) to create separate BDMV folders for each episode.
post #849 of 1017
I use DVD fab for my blus and DVDs. I use main movie because I don't need any extras or menus. I currently run my wd usb3 external to my Sony bdps580. I can play m2ts with my hdd but not mkv. Funny can play mkv DVD but not mkv bluray. Can't play anything over cat5e. Maybe too much bandwidth.
post #850 of 1017
Bandwidth shouldn't be an issue, BR video+audio nominal rate is 48 mbps (and thats as much as it can get), this is just 6 MB/s. You should be able to sustain this rate on a 10/100 LAN (not to mention Gbit). If you have issues I would say that network wouldn't be the bottleneck.
Specs on your Sony BR-Player says "MPEG-4 AVC (.mkv, .mp4, .m4v, .m2ts, .mts) : BD/DVD/CD/USB/DLNA" so in theory your HD MKV rips should run fine.
Nonetheless, feel free to post a sample of your problematic rips and I can double check to see how they run on the AIOS.
post #851 of 1017
Yes, I have been able to do what you suggest in some series such as "Homeland" but not in some others such as "Sons of Anarchy" where only the longest episode was retained.
post #852 of 1017
When you unpack the ISO you will end up with a BDMV folder, from that structure you can just select and play the m2ts track you want.
post #853 of 1017
So wouldn't you be better off storing the BD in so-called "folder" form in the first place rather than creating an iso and unpacking to folder form?
post #854 of 1017
True, though I am just trying to suggest a workaround rather than suggest changing the way you rip your collection smile.gif
For my usage ISO is fine (single file easier for burning backups), main track is enough for my needs, when I need more I just mount the ISO on my PC (using daemon tools) and just share the mount location over the network and I can select the tracks I want from the AIOS, yes its a little unorthodox but I don't have to do it frequently, else I would just backed up in BDMV instead.
post #855 of 1017
post #856 of 1017
I have the AIOS set so subtitles are always on and it works fine. However, when I haven't completed watching a movie and come back, say a day later, the subtitles are always turned off? Any solutions to this?
post #857 of 1017
Have you tried installing the latest semi-official firmware? That is the firmware I am running and subtitles are always displayed regardless of where I start or left off watching movies.
post #858 of 1017
I'm running R21.
post #859 of 1017
Hmm, that is strange. Maybe the format of the movie makes a difference? I have tried BDMV and iso for DVD. Both work fine.
post #860 of 1017
Any info on aios being able to play sacd ISO, in 2ch or 5.1?
post #861 of 1017
Any link for a sample ISO to test ?
post #862 of 1017
That's an interesting idea but I don't think there is a codec for an OS other than Windows.
post #863 of 1017
i only have a couple, but of 500MB+ sizes.
post #864 of 1017
What about extracting a small dff file from the iso?
post #865 of 1017
What would be nice is if these device manufacturers stole a page from GoogleTV....HDMI passthru, so there's no need to change inputs
post #866 of 1017
The SACD-ISO doesn't even open on the AIOS.
Can you elaborate ? HDMI pass-through works just fine.
post #867 of 1017
I noticed only one HDMI port on the rear. When I refer to passthru I mean like how the google TV boxes manage it. There are 2 HDMI ports, an input and an output; so in the instance I have my directtv box connected to my Visio co star and the the output from the co star goes to the TV, that way there's no need for me to switch inputs on the TV to access content from my google TV box.
post #868 of 1017
Oh I see, HDMI input you mean (got confused with HDMI audio passthrough), would be a waste if they are just using this for what a $5 switch can do. A more interesting use for HDMI input port would be to allow PiP and also PVR functionality (wonder if GTV boxes can do that).
post #869 of 1017
Are the Western Digital "Green" drives suitable for installation in the AIOS?
post #870 of 1017
i have same question, but rephrasing the question - any considerations purchasing internal HDDs to install inside AiOS?
