Originally Posted by coyoteaz
You're simply wrong if you think that the picture out of FiOS should be perfect at all times. Some channels are just crap to begin with (Rainbow, NBC Universal, Discovery), while others apparently turn to crap when converted to MPEG2 (Scripps) but aren't as bad in MPEG4. Hard to get true comparisons to DirecTV considering that they lock everything down. Food HD on FiOS is pretty nasty if you go frame by frame. These are from a recording I just made on Food HD of whatever crap reality show happens to be on at this time of night. I assure you that the nastiness is not due to any sort of signal issue, but is entirely the fault of excessive compression.
My point demonstrated, FiOS is still better than providers like Comcast, TWC, Dish, and U-verse, who all have the same poor sources to deal with, but also cram too many channels into too little space. Verizon could take better advantage of their additional capacity and crank up the average bitrates - Food sits at something like 14 on average and will spike up to near 18, but an average closer to 17 might result in a less sucktastic picture on wipes, dissolves, and fast pans.
That is pretty much what I see. I did change my TV setting from 16x9 to just scan and that did help a little bit.
Thanks for your help everyone, I can cancel my appoitment next weekend, so I dont waste the techs time looking for something that is normal.
