AVS › AVS Forum › Video Components › Home Theater Computers › is 200w psu enough to power a intel g620?
post #1 of 7
i'm planning to build an super budget htpc. its only going to be used to download off usenet and play 1080p mkvs. it will be with an intel g620 cpu and a dvdrw optical drive. will a 200w psu be enough?
this is the case/psu i'm planning to buy
http://www.newegg.com/Product/Produc...82E16811121115
thanks for your help!
post #2 of 7
post #3 of 7
Yes.
I'm powering one and a SSD with 120 watt PICO.
post #4 of 7
thanks for the quick reply guys.
post #5 of 7
G620 w/ 72W power supply here with no problem. In real usage it never goes over 40W w/ an SSD, 250GB notebook drive and a tuner card.
post #6 of 7
Wow impressive datapoint, you should add it to assassin's thread on power consumption...http://www.avsforum.com/avs-vb/showt...1#post21025171
post #7 of 7
Max power consumption of a G620 system (2 memory sticks, 1 SSD) is ~50W DC (at simultaneous full CPU and GPU load), that is the value you need to know when you choose a PSU.
