I have a 1978 Mini Cooper and am in the process of adding a radio to it as it did not come with one from the factory. The interior of the car was packaged very efficiently which means there really is not much unused space to add a speakker. I was able to find a location for two 6x9s in the back under the rear seat, and snuck a head unit under the dash using a universal mounting kit, but at this point I have no front speakers, and do not have much room to add anything.
What are the smallest speakers out there that I can consider? I took a look at some 3 1/2" units but they seem a bit too large to fit. I could fit something more in the 1-2" range but all I see in that range are tweeters, not full range speakrs.
Does anyone make a 2" or under full range driver? I understand that it will have very poor low freq output, but by full range I mean 200 Hz and up.
How bad do you think it would sound if I only mounted a 1" tweeter in the front? Who's tweeters work to the lowest frequencies?
-Joe
-Joe
