AVS › AVS Forum › Video Components › Home Theater Computers › HBO Choppy (ceton infinitv)
post #1 of 3
Hey Guys,
I have the ceton infinitv 4 and everything has been working fine with one exception.
Every once in a while HBO channels will run really choppy. This only happens with HBO. If i reboot the machine HBO runs fine.
Any ideas on what would cause this? My SNR is fine along with everything else
post #2 of 3
What GPU are you running? I had the same problem the first time I installed my InfiniTV4. On an AMD GPU, the solution was to uncheck de-noise (actually, uncheck all the settings in the same section) in CCC.
post #3 of 3
i actually have the same problem... also on the discoveries with certain problems too...i guess its the 29/59 bug? I have the 6570
