AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › marantz vp11s2 step down voltage question
post #1 of 3
Hi All
Does anyone know whether a US model Marantz VP11S2 (which displays next to the AC input on the back of the pj "120v~60hz") will automatically do a step down if fed 240V (ie a Europe/UK voltage). I want to avoid an external step down transformer if i can avoid it.
Thanks for any advice etc
post #2 of 3
In case it helps, I own a VP15 and I have an external step down transformer to use it, we have 220V in Uruguay.
post #3 of 3
Hi Matt, sent you a PM. Hope you enjoy your 11S2 as much as I am mine.
