I'm certain this is an easy question for y'all, so I apologize in advance.
We're in the process of redoing our basement which is allowing me to finally wire everything in wall for our networking and media center needs. I think I've got everything under control for all the pieces except ... the subwoofer.
I have one a Klipsch KSW-10 sub. I tried posting an URL, but apparently I'm too much of a noob. Forgive me that.
My current plan has 16AWG2C speaker home runs back to the distribution point, but what I wasn't sure about was the "pre-out" connection from the receiver (Sony STRDE995) which has a single SUB PREOUT RCA port back to the sub, which has the two RCA/LFE ports. Before the basement flooded, I vaguely recall having purchased some special cable for that purpose, but with the chaos since then, and all of that stuff being buried WAY in the middle of a fully packed garage, I can't even check.
All of that having been said, what would you say is the "right" cable grade/shielding/etc for that particular run? Can I just use another speaker cable run? RG6 with RCA termination? something over CAT6?
Thanks in advance for any advice...
- ZJ
- ZJ
Isn't that a bit...ironic?
