I'm trying to figure out how I'm going to get stereo output from a media player to 4 speakers (two left, two right) and a subwoofer. The speakers are JBL LSR2325P and the sub is JBL LSR2310SP.
I guess normally you would plug into the stereo inputs on the sub, and then run XLRs to the two speakers from that. I considered splitting those XLR outputs, but I'm told that would introduce noise.
If I can avoid it, I'd rather not get an expensive mixer, I really just need a way to send sound to 5 speakers via RCA, 1/4", or XLR cables.
I bet this is simple! If you could take a minute to help I'd be very grateful!
