AVS › AVS Forum › AVS Forum Information › Forum Operations Center › possibility to save posts?
post #1 of 8
Is there a spot to save "posts" into some sort of personal folder. What i mean is... There are many replies or posts on threads with great information contained. I was trying to find a way to copy those specific posts and save them to a folder. I usually have a hard time re-finding those posts to use as references. It would be great if I could save these posts to a seperate folder for review at a latter date.... Cause its difficult to find them weeks down the road. I'm sure server storage space probably plays a role in this limitation. However could be offset and only available to paid subscribers as an added benefit perhaps???
post #2 of 8
Hi,
If you look above and to the right of your post, you'll see "Thread Tools". That's a dropdown that will then give you the option to download the thread.
post #3 of 8
Mr. Lang:
I mainly use the mobile version, both iPhone and android based. I can't see that tools tab on either of them. Is there a spot on the mobile version I'm overlooking? Or is it on computer based version only? Also.... Since I can't see it at the moment, in the tools portion you mentioned download thread. Does this mean download the entire thread and all posts to your computer? I was looking for a way to just save like 1 post in a thread to a folder.
post #4 of 8
Yes, it only works for the full site version and would download the entire thread. To save an individual post, I'd just copy/paste.
post #5 of 8
Very well then.... I'll keep my notepad handy while out and about and cut / paste when I hit the desk top. Much appreciate you quick responses.
post #6 of 8
Hi can we still save threads with the new format? I'm sure it's staring right at me but I can't seem to find the thread tools anymore. Thanks.
post #7 of 8
You can print to .pdf, but there's no native tool built in.
post #8 of 8
View Single Post functionality would be very helpful.
  Back to Forum: Forum Operations Center
