AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Need Toshiba Firmware YA12 for RD-KX50 DVD Recorder
post #1 of 44
There is little discussion of this firmware and recorder on this site. Does anyone know where I can get this? It used to be available as a download from Toshiba.
Tom
Finally got through to Toshiba over phone after holding for about 45 minutes. Rep said there is no firmware update for the ya10. I insist there is. He goes off a couple times trying to find something. Insist some more. He goes off.... CLICK.
He got my phone number, and doesn't appear to be calling back.
So Toshiba is denying there is one.
On this site, there is a discussion of a fellow who posted on 3-31-2010 that
"...Toshiba is sending me a disc..." where we're talking about the YA12 for the RD-KX50.
I wonder if Repair Guys hoard firmware discs?
post #2 of 44
Originally Posted by 6volt View Post
On this site, there is a discussion of a fellow who posted on 3-31-2010 that "...Toshiba is sending me a disc..." where we're talking about the YA12 for the RD-KX50.
I'd guess you've already tried sending a PM to the AVS member who posted that info? He's probably your best hope for obtaining the elusive firmware upgrade. If he doesn't respond, you're unlikely to get anywhere with Toshiba HQ: as far as staff there is concerned, no Toshiba recorder exists prior to the 2007 OEM rebranding contracts with Funai. The classic "genuine" Toshibas are effectively orphaned, along with several vintage Sonys, JVCs and Pioneers. The supposed "7 year support commitments" are routinely cut short by mfrs: if a product is older than four years, it vanishes from their archives (especially if the unit predates current subcontracting arrangements).
post #3 of 44
He beat me to it!
Before it occurred to me to PM him, he PM'd me!
So I should be OK.
Still, I think this thread may be of future use to others that find themselves in the same predicament.
NOTE: It really torque's me that these manufacturers (allegedly) do not keep old documentation, firmware, service manuals, etc. when all they are are computer files which take up negligible space and overhead.
Another travesty is if you want to purchase restore discs for your PC and they are XP SP1, which is now not supported by MS, they will not sell them to you. Even though they can be updated to the supported SP3, they will not let you have them. (I just can't wait until MS quits supporting XP altogether - I wonder if they will also quit activating anyone's installation past that date?)
I hate to say this, but maybe this is something the government should look into. Maybe the FTC - they sure went after manufacturers' bogus amplifier power specs.
post #4 of 44
Problem Solved! YA12 fixed everything.
post #5 of 44
What kind of problems were you having,also will that firmware work on the xs-52?
Think both units are the same just xs-52 have larger HD.
post #6 of 44
The only problem was as originally posted, couldn't get the HDMI to work with my older DVI input TV.
As far as the model 52, I don't know. You'll have to do some searches.
I thought it was a good idea to start a thread with "firmware" and "RD-KX50" in the title since it is such an important issue. Maybe you should do the same with your model 52.
If you need a copy of the YA12, I can send you a copy.
Good luck,
Tom
post #7 of 44
Sure would like a copy. I did download the one for XS-52 few years ago but someone on this site or elsewhere said that toshiba download was corrupt gave him all kinds of problems after installation.Never did install it but i still have it.
post #8 of 44
OK, as long as you're sure YA12 works on the 52.
PM your address and I will send you a copy. (Beware, I will be slow getting around to this - my home PC is fubar and I've been limping along using the PC in the small office where I work.)
Tom
PS. There should be some way to put the .iso image on-line for anyone to download - something like photobucket. Maybe someone knows where to do this and can let me know.
post #9 of 44
I will use it on the kx-50 only, thanks.
post #10 of 44
Hello...I recently found this forum and am VERY interested in getting a copy of the YA12 firmware for the RD-KX50 DVD recorder. I CANNOT get mine to work with the HDMI port and it's driving me crazy. Every time I power it on with the HDMI cable plugged in, it locks up. If I use component cables it works fine.
Will this firmware fix that? If so, let me know and I will buy a copy....
Thanx so very much!!
post #11 of 44
I am also looking for way to upgrade my firmware. If someone has a copy let me know.
post #12 of 44
I am trying to use my player with my newer samsung LED TV and now having any luck with HDMI.
Does anyone have a firmware file they can send me?
Thanks in advance.
post #13 of 44
Does your Toshiba remote have an HDMI button? If so, did you press it?
post #14 of 44
When I try and do anything when I have the HDMI wire plugged in the player freezes up.
If I turn it on without the HDMI plugged in it works okay.
post #15 of 44
Some Samsung HDTV's are notorious for requiring a specific handshake (turn-on procedure).
Try leaving the HDMI cable in and turning on the Toshiba 1st, then the TV. If no joy, try the opposite. Start each from both units off, and let the first unit get up to speed before turning on the other unit.
If you get it to work while connected, press the HDMI button on the remote multiple times to go thru the HDMi formats (480p, 720p, etc.),.
post #16 of 44
No luck. As soon as I turn on the TV the player then stops responding.
post #17 of 44
Did you turn TV on 1st, then Toshiba?
And when you say it doesn't respond, does that include the HDMI button on the Tosh remote?
post #18 of 44
I tried HDMI with a few other tvs in the house. No go. The thing just doesn't like to work with HDMI.
I eventually gave up and hooked it up to a TV with component. I was trying to get it going so I could transfer an old VHS out to DVD, of course after I did that I found the same recording was already on youtube. LOL
post #19 of 44
Is there anyway you could send me the firmware or place it somewhere all can download?
post #20 of 44
I finally found my copy of YA12 - it was at work under a very old pile of paperwork on my desk.
I'm going to try and find a place where I could put it on-line for anyone to download.
If anyone knows where I should do this, please let me know.
Tom
post #21 of 44
You should be able to Attach it in a Reply here, using the paperclip icon in the edit window.
If you have a .zip file, or can ZIP it before uploading, that's best to avoid a LONG upload time and possible timeout.
post #22 of 44
I'm trying to create an .ISO image but I can't get any of my drives to recognize the disk. I'm using ISOrecorder to rip the .ISO and it won't do anything because the disc is not recognized.
Any ideas?
post #23 of 44
Hi, Found this forum after googling the hdmi problem with my toshiba RD-KX50 hdd/dvd recorder. It works great with component cables but freezes up when I try to use an hdmi cable. I would like to get a copy of the YA12 firmware if you are making copys and sending them out(I can pay you) or did you find a place to put it on line for download. THANKS
post #24 of 44
Well, I tried to attach it and ISO is NOT ALLOWED on this site.
Kind of ironic, huh?
Tom
post #25 of 44
Why not try the original (raw) filename, whatever that is? I've successfully linked to other FW files with .mot and .dtv extensions, and there are prob. others that will attach OK, esp. if they are "text/code" files.
post #26 of 44
Will someone please Quote this post so 6volt will be sure to see it in case he has me on his Block list!? biggrin.gif
post #27 of 44
I don't know what you mean by the original file name.
The disk is unrecognizable by Windows - in fact, 2 perfectly good drives would not even "mount" the disk. Lucky, the 3rd drive I tried, did. (This is probably because they use some kind of weirdo file system on the disk.)
So the only thing I know of is to rip an ISO.
But noooo, the first ISO ripping software I tried would not work because the disk was unrecognizable by Windows.
So finally, I got one that did and extracted the ISO.
_______________
Right now I'm looking in Google Drive or one of the many free online backup file services out there. Issues with them are making binary, encrypted, or data files available to the public.
This Nanny State stuff is really ticking me off and I've about had it with Toshiba too - didn't they throw HD-dvd under the bus for $400,000,000 from Sony???
If anyone has some bright ideas, I'm all ears.
Tom
PS. If it comes to it, I will send via US mail for free, but I'm really determined to get it hosted so anyone who searches for it will find it. Frankly, I'm surprised there's basically a black hole when you do a search for this firmware.
Edited by 6volt - 10/9/12 at 8:58am
post #28 of 44
_______________
As I've said before, take that FW file (which has to reside somewhere in your disk's file system), whatever it's type and filename, and try to attach it. If it takes too long or times out (due to file size), ZIP it. The Attach menu/system can also refuse certain file types.
If so, and if using a PC with WIN, you can open File > Send to > Compressed (zipped) Folder. Mac might also have a similar "file-zipping" (size-reduction) system.
Then, Attach the ZIP file in your post with the paperclip icon.
You don't HAVE to ZIP if the file isn't too large, but it might take a while to uplaod and I'm afraid it'll time out and you'll think it won't work.
I successfully zipped a 12.5MB .mot FW file to 3,5MB and it Attached pretty fast compared to my 1st try with the 12.5MB unzipped file.
Edited by wajo - 10/9/12 at 9:15am
post #29 of 44
When you bring up the disk in Explorer (File Manager), the disk appears empty - there are no Files nor Directories displayed. There is nothing to click on.
However, you make a point. Zipping a file is a common practice. Since the ISO is 14mb, I'll try zipping it and attaching it. I can't remember if ZIP is allowed, but we'll see.
post #30 of 44
So the file is on a separate disc, and inserting it doesn't show anything to copy to your HDD for zipping, uploading, etc.?
I wonder if the Sonic "RecordNow" app typically pkgd with WIN can "see" the file. If so, you could use RecordNow to create an "Esact Copy" first, which places a temp. file in queue for then creating a "Data Disc." It'll give step-by-step instructions... pretty easy.
  Back to Forum: DVD Recorders (Standard Def)
