Would the Optoma 33HD be a good 3D projector for my room?
Attched are the pictures of the front and back.
It's a bit less than 108 inches wide.
The room is about 16-17 feet deep.
I'm thinking of using this screen:
FAVI HD-100 16:9/100-Inch Electric Projector Screen
And pulling the wood crown forward from the top. Then mounting the screen mechanism on the ceiling behind it to drop in front of the cabinets.
In the back I could just mount the projector on the ceiling, or cut a hole near the left vent which is the intake vent. The cables for the projector would easily go into that vent area of the ceiling and down into my cabinet, so that shouldn't be a problem.
But I am not sure if the 33HD will have the right throw to fill the 100" screen at about 16 feet?
I can get the 33HD off Amazon for about $1420 and the screen is about $170.
What do you guys think?
