AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Software Recommendation For Room Design?
post #1 of 4
Hey Guys,
I am starting to think about and plan my media room. Any software packages that aren't crazy expensive that you guys could recommend?
-Evangelo2
post #2 of 4
I used Punch! Architectural 3000 (I got it for about $40). It worked well, but Google's Sketchup is an excellent tool. The Punch! products allow the generation of material lists.
post #3 of 4
http://www.draftsight.com
Free AutoCAD clone. Don't bother though unless you already speak AutoCAD. Your time is better spent building stuff than learning convoluted software.
post #4 of 4
Have a look at this guy's design. If you like it, the free program is from SweetHome3D. As opposed to a general purpose graphics tool like SketchUp, this is aimed at room/home designs. It's easy to learn.
But a lot depends on what level of detail and precision you want to include.
