AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Klipsh rw12d sub
Klipsh rw12d sub
post #1 of 13
hi just got a new klipsh rw12d subwoofer iam running it to a marantz 6005 reciever with a subcable.i would like to know if anyone has any settings for the sub as to which to use punch or depth or flat. also which volume to set on the sub. i had it at 0 and it sounded boomy thinking to go minus instaed of plus.also on the back what should be the hz setting on the sub
post #2 of 13
Try the "FLAT" eq and set the crossover all the way to the right wich turnes it off, thats what i use, or set it low to 60 or 55, somthing like that, its a good sub for the price, try that out and see if you like it.
post #3 of 13
I assume you have a 5.1/7.1 receiver. If so set it to flat with crossover to off and have your receiver does bass management.
post #4 of 13
are you sure you have the RW-12D? if you do it should be on the top of the sub.
post #5 of 13
I like the humor of the Klipsch engineers to make the digital level adjustment go to "+11".
post #6 of 13
Why is it so funny?
post #7 of 13
Josh See......
http://en.m.wikipedia.org/wiki/Up_to_eleven
Had to use mobile wikipedia because of the SOPA blackout.
post #8 of 13
Josh See......
Ok i see now.
post #9 of 13
makes me chuckle every time i mess with my sub.
post #10 of 13
Funny
Anyway I came in here to post Newegg's Shell shock Sat sale http://www.newegg.com/Product/Produc..._-Homepage2011
Don't know how great of a sale it is, but you never know.
DJoel
post #11 of 13
Originally Posted by Djoel View Post
Funny
DJoel
thanks for the heads up. i just bought it because of this actually
post #12 of 13
You got it pal..
DJoel
post #13 of 13
Also try to pull the sub away from a corner as much as possible, if that's the way you have it,( which is the first place people, (including me) put their subs, 98% times can be the worst). Run the Room correction setting if your AVR have any, it helps tame any unwanted anomalies!
Djoel
