AVS › AVS Forum › HDTV › HDTV Technical › connecting HDTV tuner to denon receiver
post #1 of 2
I have a Denon AVR-2112CI and it is hooked up to my TV via a single HDMI cable. The TV is on the wall and all the cables go through the wall, so I have no option to add a new cable.
I bought an HDTV Tuner and want to receive the channels. How can I go about this as I cannot connect the tuner directly to the TV, I have to go through the receiver.
post #2 of 2
Use an HDMI cable to go from the HDTV tuner to the Denon, which will pass the video to the HDTV, and process and amplify the audio when you select the input the HDTV tuner is on.
  Back to Forum: HDTV Technical
