AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Best iphone controller app
post #1 of 9
Which receiver(s) has the best implemented iOS controls? At the very least, I need to be able to change sources/volume/pandora stations remotely. For example, I want to be able to be sitting in Zone 2, within wifi range, and be able to change stations/volume/mp3 tracks remotely.
Pioneer 1121-k? Onkyo nr809? Denon? Yamaha? Something else?
post #2 of 9
also, i need to be able to change zones from the iphone... for example turn on/off zone 1 while im outside listening on zone 2.
post #3 of 9
Yamaha one seems good. It's free and you can explore options in demo mode even without a receiver.
post #4 of 9
Apparently, you can download the apps and demo them for yourself. Just from first impression, it looks like pioneer > yamaha > onkyo. Any other ones I should consider?
post #5 of 9
The oRemote is supposed to be much better than the actual app made by Onkyo, but I haven't tried it. It costs $4.99.
post #6 of 9
I have posted many screenshots of ORemote for Onkyo AVRs over the last few months, I think it is brilliant. i use the dedicated iPad version and iPhone one, which seems a little cluttered after iPad, but fine for basic controls like you mentioned.
Very impressive, and the developer is constantly improving - to requests too.
Such as deleting unused Listening Modes etc.
The Onkyo may need looking at in detail if Zones are very important, as there are limitations on controls and a couple of bugs been filed to Onkyo.
Things like random not working correctly (I think in Spotify) and I think you have to do set up in Z1 then switch Z2 to Net.
If it is vital, you should investigate more.
Start http://oremote.oriole.net/oRemote/Welcome.html
post #7 of 9
iControlAV2 looked impressive, but I went Onkyo Amp in the end (iOS control was a minor factor) - no regrets with my 809. Best amp I have owned.
post #8 of 9
There are several iphone apps for Denon AVRs both FREE and for fee. There's also iRule which is similar to a universal remote to control multiple AVR brands/devices.
post #9 of 9
man I am having a really hard time deciding. i actually could really use 3 different zones, so I am limited to the onkyo 809 or the pioneer vsx53.... tough decision.
the pioneer definitely has the better stock iphone app.... does this third party onkyo app work well? Right now I am leaning towards the pioneer vsx53...
Yamaha app is also good, but they dont have an affordable 3 zone amp.
