AVS › AVS Forum › Display Devices › Display Calibration › Are monitors/ laptops better calibrated out of the box then TV's?
Are monitors/ laptops better calibrated out of the box then TV's? - Page 2
post #31 of 40
Originally Posted by madshi View Post
Correct. I do have 10bit output on my to do list. But it doesn't have a high priority at the moment because I believe that dithering the internal calculation bitdepth (16bit+) down to 8bit should produce results that are virtually indistinguishable from 10bit output. The only gain you get with 10bit output is a lower noise floor.
Thanks for answering my email
I just always assumed as under MPC-HC with Custom EVR, you can do 10-bit D3D RGB output.
post #32 of 40
Originally Posted by sotti View Post
How can you force that and verify it?
I have a monitor that I can feed 10bit RGB via DVI, but only when running fullscreen D3D. I saw that I could do that in MadVR, but I couldn't verify the rendered bit rate with the hud with ctrl-J
ManuelG at the nvidia forums has stated that output needs to be set at ycbcr444 for 10 bit to work...
post #33 of 40
That doesn't seem like a great idea. I get a lot more banding in the image when outputting YCbCr 4:4:4 compared to RGB. Even if the output is 10-bit, the 8-bit RGB to 10-bit YCC conversion is clearly a lossy process.
post #34 of 40
Madashi, the guy who writes it just confirmed three or four posts back, that it doesn't output 10bit at all, ever.
post #35 of 40
here's what he said...http://forums.nvidia.com/index.php?s...post&p=1223025
"What you need to do is set resolution to HD format 1080p, set digital color format to YCbCr444 from Adjust Desktop Color Settings and playback content that supports Deep Color. BTW, this setting will change in the future as some HDTV's falsely broadcast Deep Color support even though the display doesn't support this. As a result, the HDTV will not display the screen properly. In the future, Deep Color will only be enabled when an application calls for it. Otherwise, it will be disabled."
post #36 of 40
No look here, post #28 in this thread.
http://www.avsforum.com/avs-vb/showt...9#post21595739
The configuration of your video card != the output of software. If windows only gives you specific bit depth buffer to write into sometimes you're stuck without doing the full end around they also provide.
post #37 of 40
So, do I calibrate the monitor, the video card, or both?
Does the mac calibration tool calibrate the display or the video card?
post #38 of 40
Ideally you calibrate booth.
How much you can calibrate the monitor depends on the controls in the monitor.
Then to get best results you'll need an ICC profile, which requires software and a meter to create an accurate one.
post #39 of 40
My display is an imac 27".
post #40 of 40
I believe the little built-in eyeball it gamma tool adjust the video card.
