AVS › AVS Forum › Display Devices › Screens › I need an explanation about 1.69 and 2.35
post #1 of 2
I have 100" screen, 1.69 with Mits HC3800. DVD movies are 1.69 and most blu-ray are 2.35. When with 2.35, I put a horizontal masking on the screen (top and bottom).
What I don't know is if I buy, let's say 110" of 2.35:
Can I play dvd (1.69 format) on the wide screen? Is vertical masking all I need? Do I need to adjust the projector every time I switch playing from bluray to dvd?
post #2 of 2
You mean 16:9 (not 1.69) and 2.35:1, i.e. 16 width for 9 height, and 2.25 units of width for 1 unit of height.
Yes, you would need to zoom the projector for 16:9 content to achieve constant height and you would have unprojected areas on the sides to mask.
  Back to Forum: Screens
