This side of the pond Audio Description/Narration on OTA is done in just this manner.
On SD broadcasts a 64kbit MP2 mono audio description signal is broadcast in addition to a 192/256k MP2 stereo main programme, and viewers who want the description enable a 'receiver mix' which mixes the two signals together, removing the need to send two high-quality full mixes. The audio description audio can have metadata attached to pan it and to reduce the level of the programme sound - and viewers can alter the relative levels of the two streams.
On our newer HD OTA broadcasts we use 128k AAC-LC 2.0/320k AAC 5.1 for the main programme audio (think the bitrate switches dynamically as the audio mode is changed on a show-by-show basis) and 64k HE-AAC for the audio description feed also broadcast for receiver mixing (For some reason the AC3 implementation wasn't quite ready when the UK started HD OTA - and most chipsets wouldn't allow you to mix AAC and AC3 or AAC and MP2 - you have to use the same codecs for both the main and audio description audio streams)
