Howdy folks,
I've been absorbing information here and around the web about audio-video equipment wall treatments, placements etc. for what seems like a week and my head is just about spinning!
I've made a few decisions and think it's time to ask for some advice/opinions from people who've put one of these together. I have never owned a home theater so it may well be that I wouldn't know the difference between well-placed or not speakers by listening... (without a comparison).
I would like to put speaker wire in the walls so that it looks nice. That means speaker placement must be decided in advance!
I've read nice things about Audyssey DSX and it makes sense to put speakers in front where you can perceive better. HTPC will provide content with bit-streaming to the following:
A/V: Onkyo NR-709.
Speakers: Energy RC.
Either: 2x RC-50 or 70 with 4x RC-10s for the surrounds and RC-LCR center
or: 6x RC-LCR all over
or: 6x RC-10 to save a little dough
all with a $300 sub.
Projector: Epson 5010 or Sony hw30es
Screen: Elite screen 100"
Audio questions!
1. Can Onkyo even drive the rc-50s and 70s satisfactorily?
2. It's mostly a theater application in a small room, would I benefit from uniform LCR or RC-10 or will I reaaallly miss having rc-50?
3. Can I use acoustic fiberglass instead of drywall and actually cut down on reflections? Isn't that room a reflection nightmare?
4. Which placement do you like best? (See attached floor plan)
5. What does DSX do to native DTS/Dolby pro 7.1 sound?
Video questions!
0. 10' or 12' view distance for 100" screen sound ok? If screen starts where RC50 ends, is this good height or too high?
1. might have light control issues, cuts the Sony out of running?
2. Dust/yellowing worry on LCD projectors justified?
Thanks for your help!
Look forward to hearing from you and hopefully letting you know how it goes once I gets started for reals!
Files: Pic are actual pictures, the others are scale sketches... ScreenPic shows the hole I'd like to place screen in.
A/V: Onkyo NR-709.
Audio questions!
Video questions!
. First, the Onkyo should be allright unless you listen at very high volumes. Anyway you say you'll have a sub so the demanding low freqs will be handled by the sub's amp.
