AVS › AVS Forum › Audio › Speakers › Is This Speaker Placement Ok?
post #1 of 3
Hi All,
Moving into a new place and am a little concerned about the placement of the surrounds...specifically the left surround.
Take a look at the attached image. It should give you an idea of what I am up against. Note that the sofa and the chair will actually be up against the wall.
Do you think I am going to have issues if the Left Surround, Left Rear, and Right Rear are on the same wall? Note that I plan to put the Left Surround on a speaker mount, so it will be angled a bit more towards the center.
Of course if you have any suggestions, I'd love to hear them. Thanks!
post #2 of 3
bump.
post #3 of 3
I would have to say no with my limited experience. Does your receiver have any type of room correction. If it can calibrate to the placement try it and find if you like it with out changing any setting. Keep it, but if not you may need to go to a 5.1 setup.
  Back to Forum: Speakers
