My current rudimentary AV components do not meet my needs. While I can access everything, my wife and daughter lack the interest to learn the menus and idiosyncrasies of my clunky interfaces. I can purchase a bunch of new boxes, or I can piece together a HDPC. A HDPC seems to be the most elegant solution, but it seems that the internets are strewn with former HDPC users. Should regular Joe's use HDPCs?
I can't find a device that will meet all of my AV needs:
-Easy to use interface
-Quick
-Is not expensive
-Access' my NAS
>easily finds and plays my DVD and MP2 rips (find by criteria)
>plays my home videos
>views my home photos
-Plays and records OTA network broadcasts, DVR-style
-Streams internet video and music content
-Plays DVD/BD disks
Most of these needs can be met by purchasing the equipment below for around $600. However, the interface for music and home videos will be lacking and the user experience will not match what I have seen of HDTVs with WMC.
-Keeping my current Roku player
-Purchasing a Dune player for NAS access and BD disks ($300)
-Purchasing a TiVX ($269) for an OTA DVR
I have assembled my own PCs for the last 15 years, so assembling a HDTV wouldn't be a big issue (however, I have learned that components don't always fit nicely together). I have priced components at Newegg for a pretty good system running at $870 (with exactly the case and components I want).
My biggest fear though is getting all the media applications to work right and stay working right. I have experienced the pleasure and pain of spending hundreds of hours tweaking custom remote controls and computer systems. It is not so bad if you have the time; but tremendously frustrating if you don't. I want to avoid this.
Getting a turn-key system from Assassin with OS/application already setup is also a consideration. I think I would have to spend about $1,250 for this option (though, I don't like all the parts he uses). Obviously, this is the most costly course of action....but it should idiot proof the system...right?
A well set up and functioning HTPC would do everything I need. But, I'm concerned that I will not be able to get it set up right. Then, I'm concerned that follow-on glitches and bugs will prevent me from using it in the future. Should I fear this? Thank you for taking the time to help.
-Quick
-Is not expensive
-Access' my NAS
-Plays DVD/BD disks
Uh ya ... Tivo , u gotta be kidding me . I love it !
I never heard of the Ceton Q until you mentioned it....it sounds like it could be a great device.
