I have a question regarding DirecTV and ethernet. I previously had cable. DirecTV did an install today and in our workout room I had a streamer. To get an ethernet signal to the streamer I was using the DLink MOCA bridge. This worked great.
Now I have one of the little DirecTV receivers in workout room that takes advantage of whole home DVR. I believe it is using a DECA (DirecTV Ethernet to Coax Adapter) to get programming to that TV.
Can I use that Ethernet connection somehow to get it to my streamer in the workout room. I tried using the DLink bridge in the same setup as before, but I think there are differences (frequencies and technical stuff I don't understand) that won't allow it to work.
Can I get something like this that would allow me to split out the COAX to ethernet on the other end?
I probably just need a general education on what is actually going on. Or if you can just say get this, this and this, and it will work that will do just as well.
FYI, the streamer has wireless functionality but for whatever reason I cannot get a good reliable signal in that room.
