AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › RYTHMIK Enclosure questions
post #1 of 4
Why are there ,or seem to be differences , in Ext (Vol) Enclosure sizes between (F12 and DS1200) and the (F15 and D15), which would also change Int Vol also?
F15 = 19x19x20= (7220) and the... D15= 18x18x24= (7776)
F12 = 15,75x15.75x17 = (4217) and the...DS1200 =15.5x15.5x21.5 = (5165)
Just wanted to know if anybody knows why and what difference it makes with more Int volume??
post #2 of 4
The DIY dimensions are what to be considered "optimum". The ready made subs are sized as such to factor in cost of shipping.
post #3 of 4
Hello Randyc1-you are mistaken about the D15; it is 18x18x21.5=6966. The D15SE has a 2.5" foot that is not part of the external volume.
post #4 of 4
U could be right,... I assumed that because the DS 1500 has a total height of 26.5, ( -2.5 for legs ) = 24 , i figured the D15 would of been the same ??
