AVS › AVS Forum › 3D Central › 3D Displays › samsung 3050gb glasses not working - help!
post #1 of 4
Frustrated beyond belief.... Got 2 of these bundled with the BD player that came with the UN55D8000 tv. Worked fine last night while trying out some 3D clips in smart hub. Then NOTHING...
Got new batteries, tried pairing, but they are not being responsive at all. Turned tv off, back on, tried to pair and not even a blink from the power button.
To make matters worse one of the 3500CR's that came with the tv now has a cracked lens. From 4 pairs to 1 in a flash, couldn't watch a movie we were planning on enjoying.
Anyone know how to get the 3050GB to respond to trying to pair? I even held it right next to the tv while 3D was on to eliminate the distance and source issues.
post #2 of 4
I suggest trying at a resonable distance from the TV to insure that the signal is not too strong for the glasses.
post #3 of 4
Mine usually connect at about 3' or so, but it takes a few seconds for them to pair. If you're not waiting you may be turning them off just as they connect.
post #4 of 4
Thanks finally they paired. Not sure why it wouldn't work for a while.
  Back to Forum: 3D Displays
