Originally Posted by commsysman
Years ago, in the 1960s, outrageous power specs having nothing to do with reality were the norm in stereo equipment, so they (the FTC) required that a standard power test be done at 8 ohms on both channels and published.
Now we have 5 and 7 channel receivers, and the only requirement is the same 2-channel test.
The law should require 7-channel receivers to publish and advertise only the power they actually put out to all seven channels at once at 1% or less distortion. Until that happens, we have only the tests done by Home Theater to tell us how much of a rip-off most of this junk really is, and who are the ones screwing us the hardest.
Let the following three examples illustrate the good, the fair, and the ugly:
The GOOD;
Cambridge 650R receiver: Specified; 100 watts per channel with ALL SEVEN CHANNELS DRIVEN!! (120 watts for 2 channels driven). $1600 * * Bravo; one honest manufacturer.
The FAIR;
Denon AVR-2311CI receiver; 75 watts per channel with all seven channels driven (105 watts for 2 channels driven). $600
The UGLY!:
Anthem MRX -700 receiver; 53 watts per channel with all seven channels driven (110 watts for 2 channels driven. ** $2000 **!!!!!!
Did I hear the word RIP-OFF in the crowd there? You betcha, Charley!
There are at least a dozen receivers that sell for under $700 that deliver more power to all seven channels than the $2000 Anthem MRX-700. If that isn't the worst trashing of their customers I have ever seen, then it sure comes close. If I spent $2000 for that Anthem and then learned that it had the power supply of a typical $500 or less receiver, I would be seriously enraged! I would feel like a guy who bought a Ferrari and found out it had a 56-horsepower engine.
This outrageous example should get Anthem the official 2011 SCREW THE CONSUMER award.
Most of the rest fall in the BAD category; too many (and too nauseating) to mention!
Caveat emptor!
And by the way...anyone can add some metal and make a receiver heavier; check the actual power output before you buy, not the weight!
I have a Sony SACD player that weighs 54 pounds; power output zero (SCD-777ES).
News Flash...: Pioneer has announced that their 2012 Elite line of receivers will have class D switching amplifiers. Those will definitely be much lighter than a normal class AB amplifier, so throw away your scale.
The GOOD;
The FAIR;
The UGLY!:
Caveat emptor!
uhm the law should require nothing other than passing a safety standard. To have government regulate stuff is bad.......the industry it's self must come up with a standard...
