After 5 gt30 exchanges because of brightness fluctuation issues i finally received a October build that seemed to work perfect. I turned my ps3 on for maybe 2-4 mins just to see if i would find any kind of brightness fluctuation and I didn't... So I go to set up slides for the 100 hour break in, and boom right away I see in the top right corner when slides start to run, the ps3s clock and date stuck on the screen.. I said to myself ok, maybe its because the tv is still brand new. So I leave it for 100 hours running slides. Now Im done but still everything I view stays stuck on the screen and it only has to be up for seconds for it to stick. When I turn on my tv and the box comes out with white letters no signal found, that stays stuck, any thing that is white stays stuck. The ps3s date and time always gets stuck even if it there just for 5 seconds. I always have to run the scrolling bar.
Does this mean this tv is defective? The image retention on this tv is real heavy, things need to just be up for seconds for it to stay stuck. I didn't notice any image retention problems with the other gt30s i returned. I lowered contrast and panel brightness, that changed nothing.
