AVS › AVS Forum › Video Components › Home Theater Computers › Set color on htpc
Set color on htpc
post #1 of 2
I am running a jvc rs1 projector that is calibrated for directv and bluray. Whe I switch to my htpc the colors are not accurate.
What is the best way to set accurate color on the htpc when using a projector? I am running an amd 6980 with 11.2 drivers. Thanks. Jim
post #2 of 2
you want to change your settings to match the following:
16-235 for color range/level/whatever you want to call it
6500k (or D65) color temp
2.2 gamma
709 color space
