I've had an issue for several weeks now where the TV menu will pop up by itself and then go away only to pop up again and repeat this cycle. It may do it for hours and then not do it for days but it seems to be getting more frequent. I've tried the following:
> Remove batteries from ALL remotes in the house
> Reset the TV completely
> Block the remote sensor on the TV
> Press the menu button on the tv panel to make sure it's not a stuck switch.
> Turned demo mode off/on (the issue is not the demo but the TV menu for settings but I thought I would try just the same).
I'm guessing one of the boards is flaking out but I have no idea which one. Anyone see this problem before and/or know what the cause might be? I'm savvy enough to be able to swap out boards if I knew which one it may be. Thanks.
