AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung DLP TV won't turn on -single solid red light
post #1 of 2
Hi -
A friend has a smaller Samsung DLP set - out of warranty. Plug it in, a single red light (solid, not flashing) in front. Hit the power button - nothing - Same single Red Solid light (none flashing) Tried the front panel power button, and also the power button on the remote.
Tried replacing the bulb, but no noticeable change in behavior.
Prior to this, the set had been in storage for a year (and moved)
Any thoughts on what it could be?
Could a cable have come loose during the move? Anything to check for?
post #2 of 2
Check the owner's manual for that model over at Samsung's site.
This was for my old TV, but he should be able to find his and see what they say about the LEDs and what a solid red means (may be just the lamp, which is possible after being stored/moved).
eg: http://www.samsung.com/us/support/do.../HLN507W1X/XAA
  Back to Forum: Rear Projection Units
