Originally Posted by
Dark_Slayer
We are specifically talking about a new Plex feature where you can view a video stream in a web browser
Apparently I missed where he was more clear. In this situation, it will depend if one is able to side load apps or have access to Google Play; it's possible, not always, to install apps on new devices from your app history; Google groups all devices together. I've done this on new devices that are region locked, without having to spoof Google Play.
Some devices may not have Google Play or be able to side load. In those cases, it's going to depend on what the manufacturer and designers decided to install and maintain. The PS3 has a web brower and Flash Player 10, I think. It could be 9. It just hasn't been updated in three years.
If you can side load, it would be best to try and install the Plex app over flash player because you don't know how optimized the browser will work with Flash Player.
Dark_Slayer
...for now Plex will only be able to stream your iso files locally. I don't believe there is any support for iso transcoding... For home use, I believe the roku can handle iso files so you're good there. Plex won't transcode what the clients can receive direct-stream
This is not quite right. I agree, I don't think the Roku Player can play ISOs. It was rather limited what it can and can't play directly. I think they updated it to play MKV.
Also, ISO hasn't been fully supported in Plex since the change to 9.5 and using the server. The desktop agent may have a player that can hnadle ISO for direct play so the server is just feeding a file.
In addition, the web based player that is used within a browser doesn't support all the video formats yet. I've ran into problems with M2TS files. Plex is working on the most popular formss firsts, then will add more later. Thus, ISO support will come in the future. Of course, Plex, as far as I knew, didn't support all the menus on ISOs anyway, thus it may be better to use MakeMKV which just rips the DVD/BR to an MKV container and maintaining audio and video quality.
