From listening to a mac addict friend of mine boasting about plex and plex server, I decided to try the plex server out on CentOS 6.1 self built NAS.
To my greatest surprise, the installation was over in less than three minutes...
I went further and configured my media folders et al... it was almost identical to setting up mediabrowser, because you decide on the name you want to see on the top level (movies, shows... anything) and you assign folders to watch and update.
The scrapper was not like anything I have ever seen before. It looks like it takes the first frame of the movie and finds a match, and somehow it was close to 97% success rate. I had to modify some, but it was equally straightforward.
I was so impressed by the ease and speed of install that i decided to test drive the server and bought the plex client in the app store for my iPad2.
Once again, I was completely (positively) shocked by the smoothness and quality at which 1080p MKV files were being played over my wi-fi network by the iPad2. The transcoding is spectacular...
All of this was too hard for me to believe in one evening, I invited my mac friend over the next day.
He came with his mac pro to test drive the plex server and amazingly, the plex client on the mac pro played just as flawlessly as I could ever imagine...
Since having this in place, my 4yr old has nearly killed the iPad2.
That shows how easy it is to use.
My 4yr old can start the device, start plex, choose his movie and watch.
He sometimes even goes to bed with it.
The one most impressive thing is that the plex server has served all movies at 100% success rate, it did not crash once!
I bought an apple TV2 last weekend and the HTPC in the bedroom quickly found its place in the basement.
The apple TV2 was jailbroken probably an hour after I bought it and has been running plex since then.
SD and 720p movies play fantastically well, 1080p movies not very well, but there is newer version that will be released anytime soon that they promise addresses most issues with 1080p files.
At the moment, I use airplay to stream 1080p files from the iPad2 to the ATV2... this workaround is so exciting and phenominal
All in all, there is still no replacement for the HTPC that does HD audio bitstreaming, 3D et al... but the plex setup is totally a no brainer to prefer when it comes to ease of setup and use.
I think it is also unfortunate for the XBMC folks that plex was forked out of their product... but hey... that is what life is all about...
Image quality is completely acceptable (in my opinion) if TV is well calibrated.
Audio quality not bad (excellent IMO) if you don't care about lossless HD audio (which most average users don't really care about anyway)
Final decision: HTPC in the living room stays as is with HDMI 1.4 for 3D and lossless audio support.
All others run on plex...
You have to try it to know what it really is...
My opinion on i-products has changed in the last month...
