Hi all,
I am looking into buying a new camcorder as my current one doesn't have the possibility of adding a microphone - and the build in one has worked fine for the use so far, but as I am recording more and more conversations in situations with background noise it can't do the job any more as it simply picks up too much of that background noise.
It is a jungle trying to find the right camcorder as it appears I either have to go for the really cheap small pocket camcorders or the large professionel ones, which I simply can't afford.
What I am looking for is a camcorder with min. 18 x zoom - I also need to be able to zoom while recording. (Which is what I have now), HD recording (I don't mind that it is AVCHD as I am use to that), a microphone and a headset jack and also a shoe where a shotgun microphone can be added.
I would prefer a camcorder that is not too small as I like to feel that I have one in my hand and some of the small pocket ones are simply too small for me.
My budget is not completely fixed, but I am looking at something in between the small pocket ones and the professionels.
Can anyone here guide me in the direction of some models that would be suitable?
Thanks in advance,
Thanks in advance,
