Thanx for your help ahead of time...
I have had this "problem" since I bought the SR7005 and I have gone through countless trials & errors in both the AVR & the BD player settings, have looked in all places for information & as I mentioned, read the manual several times but to no avail. I also waited until my new cables (1.4) came in to go through the motions again before I started a new thread.
The Problem is that when the AVR is set to BD (through a 1.4 HDMI cable) and I'm watching a movie (Blu-ray,) it wont let me cycle through all the available surround modes for this unit & especially anything under the "DTS" banner or the "Dolby" banner... It will only let me toggle between... multi ch stereo, dolby vs, auto, stereo, multi ch in, multi ch in PLIIz, Multi +dolby ex, multi in +PLIIxMV and multi in +PLIIxMS... basically the surround modes under "Multi Channel In" and at one point after running Audyssey & tweaking some settings to my liking I only had "sterero" "Multi ch in" & "dolby vs."
SOME EXTRA INFO:
-My BD player is a Sony S580, connected through a high speed 1.4 3D HDMI cable.
-When I depress info on the BD's remote while playing a Blu ray with DTS HD audio the screen says "AUDIO DTS-HD."
-While playing the BD I go into the AVR settings & set to decode "DTS only" & the audio playback stops.
-When the AVR is set to TV (My cable box connected to the AVR through an optical cable only -TV doesnt support ARC-) It "decodes" most of the surround modes if not all... including DTS which coming from Yamaha was weird to me since the source needed to be a DTS in order for my old AVR to display the "DTS" symbol on its display.
-When the AVR is set to Ipod it also "decodes" most of the surround modes if not all, just as if it was the cable box.
I've found this information on here, concerning my problem (or similar) but it didnt help me:
SOME EXTRA INFO:
Originally Posted by Psycho Marco
The surround mode I´m using for music is DTS Music or Dolby Music. But for some reason I´m not able to select between all the SR7005´s array of choices. In fact, yesterday I played a bluray movie, which has DTS surround sound and the SR7005 didn´t selected DTS, it set itself automatically to "All Ch In".
Originally Posted by jdsmoothie
Menu choices will be available based on the audio being received. The 7005 doesn't select DTS or "All Ch In", rather it simply receives what the source sends it. In the above case, you have the BDP set to LPCM so the BDP decodes the audio and passes it to the 7005. Set the BDP to "bitstream" with secondary audio set to OFF and it will pass the compressed DD/DTS audio to the 7005 to decode, although in the end it doesn't matter which device does the decoding as the audio quality will be the same either way.
