AVS › AVS Forum › Video Components › Video Processors › Multiple Xbox 360s + single projector
post #1 of 3
Hi there,
I would like to be able to project 2 Xbox 360's using a single projector. Some searching indicates that some sort of video processor would suit this application.
I found products by vistasystems, tvone, and networktechinc (sorry I can't post URLs yet)
Has anyone else done this?
Would you please share your experiences?
Do these sorts of processors introduce any sort of latency that might affect gaming?
Are there other relevant products out there?
Kevin
post #2 of 3
The Lumagen Radiance XE (not the XS or Mini) supports PiP and PoP (side-by-side) of two input sources.
post #3 of 3
Thanks for the quick reply.
I wonder if there is something that mixes audio from 2 sources.
  Back to Forum: Video Processors
