AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Trying to find a solid solution for component rack
post #1 of 4
Looking for something short, under 50 inches tall. 55 inch LED mounted over the fireplace, just need something skinny to hold the components. What I keep finding is cheap particleboard hunks of crap that are not worth the money. I want something made of real wood, has a glass front, and if possible ventilation, but if not I can add my own.
I'm not finding what I want on Amazon or any of the big box stores. Sanus has a nice one, but I'm not looking to spend 800 dollars, plus it's way too tall for my needs.
post #2 of 4
www.racksandstands.com this is where I got my Sanus rack.. hope this helps.
post #3 of 4
I like my full height omnimount rack. And they make a half height version
http://www.omnimount.com/products/ra...systems/rsf.5/
It's just under 600 from racksandstands
http://www.racksandstands.com/keywor...mmand=dosearch
Oh, you said wood - this is metal.
post #4 of 4
while this one is also metal, I'd suggest the OmniMount RE18 (or 27 if you need a taller unit).
if you search for it on Amazon you'll find it quickly.
It has a glass front with locking front, rear, and side panels for easy yet secure access to your equipment. it's cheaper than their RSF model, has cooling fans, and is vented at the top and bottom to keep fresh air circulating through the unit.
