I've had my TX-NR906 for almost three years without ever experiencing an issue. Yesterday I turned my system on to watch TV and a picture never appeared, just a black screen. I confirmed that my TV, Sat Receiver, and 906 were all powered on. The 906 was set to the correct input, but the display on the front of the 906 said "No Signal". This had NEVER happened even once before. I turned the 906 off and back on and it worked for the rest of the night.
Today I went to watch TV and same thing as yesterday, all components on but display reads "No Signal" from the HDMI. But today turning off and on didn't correct the issue. I then switched to my OPPO Blu Ray and same thing "No Signal".
I then did some troubleshooting. I connected both the Sat Receiver and Blu Ray directly to the TV and they both worked fine.
I then focused back on the 906. I tried bringing up the Onkyo's set up menu, nothing. I switched to the second HDMI monitor out in the menu and moved the cable in back to the second HDMI out, nothing. I did a factory reset of the receiver and tried everything again, nothing.
Again I have had this receiver for three years and never had a problem. I have swapped out new source components, but have never experienced any HDMI issues in the past. The last change I made to the system was adding the OPPO Blu Ray player just after Christmas; it has worked fine since I hooked it up. But then today, the HDMI doesn't seem to work no matter what I do.
It's almost like the HDMI board just failed; unfortunately right now that's the only thing that makes any sense.
Is there anyone else that has experienced this with an Onkyo TX-NR906?
, had it since November 2008 so can't complain too much though but it's mighty frustrating having to switch the thing on and off to get a picture. What are you guys going to as a replacement? Looking for equivalent sound and video processor quality, but ideally something that runs a little cooler!
