Cheap intercom for theater
post #1 of 10
Has anyone installed an intercom system in their theater room? Since the theater room is soundproofed it would be nice for my wife or kids to be able to communicate if I'm needed without having to come downstairs. I do not need anything special but I'm looking for a cheap basic intercom that is quiet when not in use.
Any recommendations?
post #2 of 10
my wife calls me on the phone
post #3 of 10
Not sure what your wiring options are, but I have the Russound Compoint system throughout my house (it runs off standard Cat 5 wiring).
It is a simple push-to-talk intercom that is very compact, and it works well with wholehouse audio speakers or with its own small side-by-side speaker.
In my theater I use the side-by-side speaker, as I didn't want my home theater speakers running through it. Elsewhere in the house the keypads connect with the wholehouse audio speakers in each room and it mutes the music when in use.
Works great.
post #4 of 10
Cell phones and text messages are good.
I'm planning on adding the Russound Compoint into the Theater as well and integrating with the rest of the house. But I may also tie into my automation system to turn on some light in the room in case the movie is really loud.
Assuming the wife doesn't abuse it, I'll probably also allow her to pause the movie.
post #5 of 10
Cell reception in my house spotty, at best. We use a cordless phone system with an intercom...works great! I bought extra handsets for total of 6....4 in the bedrooms, one on the main floor and one in the basement.
You might also consider an extra doorbell. I know I can't hear the front doorbell if I disconnect the one in the basement. I ran new wires while I had everything open.
post #6 of 10
You might also consider an extra doorbell..
My dogs make a good doorbell extender.
post #7 of 10
Great idea on the cordless phone system. I'll have to check to see if ours has that feature. - and I just picked up a doorbell chime a few days ago. I figured If I have a movie get together where I am expecting visitors I can still wait in the theater and hear the doorbell.
I think the cordless phone system will solve the problem - Even if my current system does not have an intercom it looks like a 5 phone setup on amazon is a bit over $100.
post #8 of 10
A remote IP camera integrated into iRule remote is cool (I can keep an eye upstairs...). Otherwise a cell phone is the best intercom if you really want to be interrupted!
post #9 of 10
I like the phone idea too. I've got the doorbell Fon system so it will ring the phones if someone is at the door too.
post #10 of 10
I have visitors bang on the outisde walls of the theater for entry after the movie start time.
