AVS › AVS Forum › Video Components › Video Processors › FleaHDMI > DVDO Edge (or other VP) combo question
post #1 of 3
Hello All,
I have been combing the DVDO Edge thread and noticed that a few users have the FLEA and Edge working together. I have been running the Flea for a few years and I just bought the DVDO Edge Green. It is a nice unit but lacks block noise reduction. I don't have any calibration equipment, test disks, or a way to do a side by side test so I am wondering if anyone can tell me if the DVDO Edge can / does correct the bug where the Flea converts RGB to PC levels?
I noticed that I can set my output color space on the Edge to Auto, Video, or PC - I am just wondering if anyone has done any testing regarding this color space bug with the Flea feeding a VP that can manipulate input and output color space levels.
Jay
post #2 of 3
The Edge can handle PC levels just fine. If the auto detection doesn't work, you can still set the INPUT VIDEO LEVEL manually to either Video or Computer.
post #3 of 3
Thank You.
It looks like it works fine automatically.
If I force the output to PC levels with the flea connected - It darkens the screen. If I force the input to PC levels with the Flea in the chain - it lightens the screen. - If I take the Flea out - It looks like it does when set to auto with the flea in the chain set to auto or forced to video levels out. So I guess the Edge is correcting the output levels.
JJK
  Back to Forum: Video Processors
