AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung D series FBr fix discussion
Samsung D series FBr fix discussion - Page 39
post #1141 of 1574
Originally Posted by KevinNash View Post
I really mean Brightness, I set it with PLUGEhigh of Spears&Munsil Blu-ray or black clipping pattern on AVS HD 709.
I don't understand then because you said you have to change it with room light but brightness setting only has one correct setting, level 16 not visible, level 17 barely visible in a dark room.
Do you know how to rollback my firmware ? I thinked it was impossible.
samgo.tv has the method but it's still not clear what you are trying to do. If brightness needs to be set at 79 (or whatever), just leave it there - it's not a problem. If you maximum light output is too low then you might roll-back or adjust the ADC values to increase it.
If you want to have a day vs. night setting you change gamma/contrast for that, not brightness. A contrast/gamma change will mean resetting brightness a click or 2.
post #1142 of 1574
Kevin, maybe you have set HDMI Backlevel to low, try normal if you aren't able to see all shade's of grey/black. If that option is greyed out, maybe your player or whatever is wrongly adjusted.
And for all with EU-Modells look here for english:
http://www.avforums.com/forums/plasma-tvs/1643623-how-firmware-downgrade-samsung-d-series-plasma.html
And here for german:
http://www.hifi-forum.de/index.php?action=browseT&back=1&sort=lpost&forum_id=138&thread=3653
versions of how to downgrade and download firmwares.
For those who are willing to loose their settings can use the factory reset method to correct version number of fake-firmware.
If you want to keep your settings follow step number 2 to change version number.
post #1143 of 1574
I usually set my brightness by eye in a dark room with a pattern and find the point where " below black " bars must appear/disappear.
If I do it when the room is bright, the setting is different but I suppose it's because of the insane glare oh the D550 lol wink.gif so it's very hard to see my below black bars appear/disappear in fact.
Thank you for the help, I'll use my meter and redo my cal.
After all you're right, if I must set brightness higher, that's not an issue.
post #1144 of 1574
Thanks for the links, I'll have a serious look on them.
My blacklevel is always greyed , cinema smooth engaged or not ( even before the logic board flash ).
I suppose it's because my player Dune HD-TV301 is set to output 709HD matrix but maybe I am wrong on that point ?
post #1145 of 1574
HDMI blacklevel is greyed out than YCbCr is put through. The only thing you have to check is, if the Dune HD has an option for color range, like superwhite option in PS3.
For some EU-models, like mine, there is a black crush in some conditions. And you can't get rid of that. Check your experts pattern 1 in advanced menu. I can only see the bars in the black part of the pattern at brightness at 100! On my set (PS51D6900) the build in pattern is just wrong because in normal conditions I have no black crush. But with an expert pattern like mine it is possible that your set also has an black crush under some conditions.
post #1146 of 1574
I just saw a strange thing while calibrating my set PS51D550, I have the fbrFix and o friendly firmware downgrade to the excellent 1024 so my brightness is now really great biggrin.gif :
If I put a full 100 black picture ( and no, my set doesn't shut off because my brightness is enough high ) and after that I switch to a clear picture ( orange for example ) :
There's a lot af blacks pixels who takes ages to disappear and become orange.
I never noticed that before the fbrFix, could others check that on their sets and give me feedback please ?
Thanks in advance.
post #1147 of 1574
There was one other report of pixel misfires after a logic board update here, maybe related? MrCoops later said he thought is was a defective panel to begin with.
post #1148 of 1574
I read MrCoops issue, mine is different and less embarrassing.
I'll try to explain bettre ( I am french lol ) :
If I swap from a 100% black picture to a 100% red one, some pixels continue to be black for severals seconds.
Black to red is the worst, if I swap from black to white, the black pixels disappear very quickly.
If you have a Xbox 360 you can also see by by swapping between the menus, some black pixels stay in the green background for some seconds.
Can some others fbr fix users test that on their set ?
I am sure that wasn't here before the logic board update.
Of course if there is a solution to rollback my logic board, I am interested.
post #1149 of 1574
hope some one can help me i done the downgrading firmware trick reset the tv and i have lost my tv type tuner setting in the service menu model number d550 hope some one can help:eek:
post #1150 of 1574
This is only possible by physically replacing the board. What panel size do you have?
post #1151 of 1574
It's a 51 inchs ( EU PS51D550 ).
post #1152 of 1574
Your problem sounds like a voltage on the power supply board or y-scan board is not adjusted properly. 51" models have analog voltage adjustments on the these boards and larger panels have these controls on the logic board. So I doubt that the logic board upgrade is the source of your problem although I can't be positive. If it's still under warranty I would have it checked.
post #1153 of 1574
post #1154 of 1574
I did today, the stupid phone guy told me it's screen burning, he did not understand anything at my problem mad.gif So I don't know if a tech will come to see my set...
I just did a test with my X-Rite display 2.
On a full black screen, before the fbrFix, I had a black level 0,06 cd/m², 0,0175 ftL ( 24p and cinema smooth on, so that's the worst case ).
Now, after the fbrFix, I have 0,02 cd/m², 0,0058 ftL three times less ! eek.gif
Could it be related ? I mean less black could affect pixels to be hard and slow to " wake up " to another color ?
I saw some informations about voltages on you other thread here http://www.avsforum.com/t/1390635/samsung-plasma-panel-tweaks-for-better-blacks
I want to check them, I saw the VA and VS test points but how to use the voltmeter ? If I want to mesure VA, I put on pin on the voltmeter on VA test point but where do I put the other pin ?
post #1155 of 1574
yes, low mll is associated with pixel misfires. .02 vs. .06 is a big difference, you should see a much improved image. Probably the easiest thing for you to do is to turn the Yrr pot just slightly CCW to remove misfires. To check the voltages put the positive probe on the test point and the negative probe on the closest board screw.
post #1156 of 1574
Thanks again for the help, very appreciated. You are right, my black bars are really inky, never see that before eek.gif Previously they were black-grey.
Perhaps my set was already on the low limit and the logic board flash revealed the problem ? Strangely it's a EU D550, as MrCoops.
In fact the PQ is not so good, it seems I losted black details, the PQ looks " too black " to me certainly related to the pixel misfires thing.
Is there a voltage or a low mll you can suggest to me ?
And what is CCW ? Counter clock wise, so screwdriver to the left ? I am french and french people and english, you know rolleyes.gif So I prefer to ask wink.gif
Edited by KevinNash - 6/25/12 at 3:36pm
post #1157 of 1574
And what is CCW ? Counter clock wise, so screwdriver to the left ? I am french aond french people and english, you know rolleyes.gif So I prefer to ask wink.gif
tongue.gif yes, CCW=counter clockwise turn to the left, but only a very small amount. You want the lowest mll possible without the pixel misfires. If you lose black detail it's because your brightness or gamma setting is too low not the mll. I suggest you run the internal pattern under the screen burn protection menu "scrolling bar" and then adjust the Yrr until this pattern is clear.
post #1158 of 1574
Good idea, I clearly see the pixels misfire on this scrolling pattern.
post #1159 of 1574
is their a firmware out their for the 550 as the things like a radiator not good for the summer nights
post #1160 of 1574
You mean a firmware which reduces the heat from the TV? No, that doesn't exist - sorry.
post #1161 of 1574
i used to own a panasonic pwd6 and thats was fine
cheers anyway might be time to move to an led i think
post #1162 of 1574
I just had my tv repaired, well all of the guts replaced except the power supply and speakers to fix the exact problem you're having. They tech said it most likely was the logic board but couldn't say for sure being that they don't actually diagnose the problems on site, the just replace everything and send it back to samsung to be diagnosed.
Anyways the tv is working great and the issue is resolved. Keep pressing the issue with samsung but just don't tell them anything beyond what the issue is. Also go directly through their website and fill out the repair form. The people they got working the phones are pretty useless so don't even waste your time with them any more.
post #1163 of 1574
What size/model? Did the problem appear as a result of upgrading the logic board firmware?
post #1164 of 1574
I just want to be sure exactly what I am doing so to clairfy I do 2 steps?
My TV is the PN59D8000 & I have done the following step:
To install the firmware:
-Unpack/unzip firmware and place the image folder on your USB stick in a folder named T-GAPxxxxx (D8000),
T-MSTxxxxx(others)
xxxxx=8AKUC (D8000)
xxxxx=5AUSC (D6500,D6900,D7000)
xxxxx=4AUSC (D550)
-On TV hit menu->support->software upgrade->by usb
I did verify I now have following version on my logic board:
PN59D8000: 11-11-04
& I did see the optimization screen
Now my question is am I done or do I continue on with the following step:?
Logic Board Update Method
By this method you can manually apply the second step of the official firmware upgrade process. This step will upgrade your logic board to the version which eliminates jumps in black level luminance (pops). This update will not change your minimum luminance level (mll) nor will it eliminate black level rise during bright content, all it does is remove the pops that were so noticeable in the previous revision. The logic upgrade can be performed over any FW version.
D8000 procedure
1. Download this file.
2. Extract file for your model from list below and rename it to LOGIC.bin- Note: If you have "show extensions" turned off in windows rename the file LOGIC
3. Place on stick in folder PDP_LOGIC
4. Turn on TV and attach stick to USB 1
5. Press mute+7+3+7+enter
6. Check Logic SW version
7. Check panel version (DS or DF)
8. Navigate to Logic USB D/L and select it
9. Right arrow to initiate flash (no turning back here)
10. "Upgrading" will be displayed if the TV accepted the file and this takes a minute or so and then the TV reboots.
11. Recheck Logic SW version.
Just want to be 100% certain that I do indeed need to do this 2nd step( Logic Board Update Method) before doing it, Thanks in advance
post #1165 of 1574
Hi
Will it work on Samsung Smart TV UE46ES5505 with 1021 firmware?
post #1166 of 1574
PN59D8000: 11-11-04
post #1167 of 1574
Originally Posted by christiansenn View Post
Hi
no, D-series Plasma only, also this problem has been reported fixed for the E-series, at least on the 6500.
post #1168 of 1574
I have a 51D550. I assume it was from upgrading the logic board firmware as I didn't have the problem before doing it as well as the symptoms being the same as what others reported after upgrading to the FW.
post #1169 of 1574
Hummm so like me and MrCoops, EU PS51D550 too ?
Did you remark a very low black level after the update ( that's my case, as I said before, my blacks are 3 times lowers since the logic board update ) ?
post #1170 of 1574
Hello, here are my logicboard menu shots :
Before :
560
After update :
560
As you can see, Panel temperature and MRT values are different before and after the update ?
Do you know why ? Is the temperature the " real " temperature of the panel and what is MRT ?
Could it be related to the misfires problems of D550 users ?
