Originally Posted by
Soopermario
So about 850 hours and the FBR is back. When did you notice it? How many hours approximately before you looked after the 850 / 878 hours?
And we need people with their hours who don't notice FBR after the logic board fix. If there are people with 900+ hours and no FBR you can hope that it will soon be gone. But if even with 1000+ hours the FBR is still there than maybe it's not the logic board software that causes it.
The hours you noticed normaly have to be the ones from the first power on of the panel. But if the logic board update resets the hours then it will be more difficult to compare different set's.
Did someone look after the MRT-entry in logic menu after the fix? Does it stay unchanged or is it reset?
If we know all this we can make further speculations.
Soopermario,
The MRT on my 64D7000 reads 1258 and I have had absolutely no brightness popping since updating the logic FW on a new replacement panel which included a new logic board..
BTW, where did you find that the value of MRT represents the hours on the panel? I have not seen that information anywhere and zoyd previously stated that he did not know what it represented.
@BShmal and JMUdukes: What version software have you installed?
Oh. yes. This thread is devoted to the D models not the E series.
Larry
