Originally Posted by
zoyd
Having said that, many people have upgraded successfully and I've performed it on my 51" D8000 twice without any problems. LarryInRI has tested on the D7000 and it works properly (D550 has not tested been tested yet). The D7000 requires you to use the factory remote emulator
ruSamsungCommunicator to unlock the logic usb d/l menu item, you need to connect to your TV with the emulator and press info+factory.
Tips on using the emulator:
1. Yes, I know it's in a foreign language, buck up and use google translate.
2. Make sure your display has "wireless remote control" enabled (TV can be hard wired or wireless)
3. On first connect your display will ask for permission to control, click yes of course.
D8000 procedure
1. Download
this file.
2. Extract file for your model from list below and rename it to LOGIC.bin
3. Place on stick in folder PDP_LOGIC
4. Turn on TV and attach stick
to USB 1
5. Press mute+7+3+7+enter
6. Check Logic SW version
7. Check panel type (
DS or
DF)
8. Navigate to Logic USB D/L and select it
9. Right arrow to initiate flash (no turning back here)
10. "Updating" will be displayed if the TV accepted the file and this takes a minute or so and then the TV reboots.
11. Recheck Logic SW version.
D7000 procedure (probably the same for all models below D8000)
1. Download
this file.
to USB 1
DS or
DF)
8. Turn off TV and turn back on
9. Establish a wireless connection with the emulator in the Fernbedienung tab
10. On the emulator, hit the Info button and then the Factory button to get into the Service Menu
11. Navigate to SVC and select it
12. Navigate to Logic USB D/L and select it
13. Right arrow to initiate flash (no turning back here)
14. "Updating" will be displayed if the TV accepted the file and this takes a minute or so and then the TV reboots.
15. Recheck Logic SW version.
Messages you might see when upgrading:
"Failed" -> TV could not find an upgrade file, check to make sure LOGIC.bin is in folder PDP_LOGIC.
"No Match" -> TV found LOGIC.bin but doesn't like it.
"Updating" -> You are golden.
Timing board flash files:
TCON.zip contains the following files from the FW bundle which are identical for both the D7000 and D8000 models (unknown if they work on D550). These files should also work for the D6500 and D6900 displays since they all use the same logic board.
51DF_DeepBlack.bin
51DS_DeepBlack.bin
59DS_ITO_DeepBlack.bin
59DS_ITOless_DeepBlack.bin
64DS_ITO_Deepblack.bin
64DS_ITOless_DeepBlack.bin
51" panel use -> 51
DS_DeepBlack.bin or 51
DF_DeepBlack.bin (depends on panel type)
59" panel use -> 59DS_ITO_DeepBlack.bin
64" panel use -> 64DS_ITO_DeepBlack.bin
Note: If the ITO_DeepBlack.bin file does not work for you try the ITOless_DeepBlack.bin, some panels prefer one over the other (don't know why).
